Internal and zero s...
[Closed] Internal and zero stack the same as semi integrated?
Well is it? Need a 'semi integrated headset' for my commencal combi frame i bought of taka not so long ago. Will one of these work:
http://www.chainreactioncycles.com/Models.aspx?ModelID=27947
http://www.chainreactioncycles.com/Models.aspx?ModelID=29301
http://www.chainreactioncycles.com/Models.aspx?ModelID=15888
http://www.chainreactioncycles.com/Models.aspx?ModelID=28807
Which one??? Gonna use my chainreaction voucher as some other people have recently got so would rather chainreaction. Cheers
Posted : 31/03/2009 5:46 pm
sure one of u clever people know the answer to this
Posted : 31/03/2009 6:51 pm
Dunno about cleaver but I have been trying to sort out the same thing myself. Think you are OK with the Cane Creek and PZ Racing ones.
Think the FSA one is not semi-integrated/zero stack/integral but internal (bearings rest in head tube, not in a cup) and not sure which Pro-Lite one you would need.
I was thinking of Cane Creek ones simply because it is a knackered Cane Creek (OEM unsealed thing) on my bike at the moment.
Posted : 31/03/2009 7:00 pm
hmmm interesting. I dunno now?! This is my attempt at learning about building up bikes. So far, all I've done is take out an existing bottom bracket. 2 months down the line. HAHA
Posted : 31/03/2009 7:07 pm
Found an explanation somewhere once, will try to find it again...
Posted : 31/03/2009 7:23 pm
[url= http://www.parktool.com/repair/readhowto.asp?id=68 ]Found it here at Park Tools[/url] and you were right, they are the same.
Glad you asked so I had another look "might" make it easier when I do mine.
Posted : 31/03/2009 7:28 pm
So will any of the above be ok?
Posted : 31/03/2009 7:30 pm
Ah, well, ermmm, yes? It is all a bit confusing isn't it? Personally I am going to buy one, remove mine, and check it against the new one whilst it is still wrapped. Not sure of difference between Cane Creek and Semi-integrated on the Pro-Lite one.
What is on your bike now?
Posted : 31/03/2009 7:46 pm
My bike is a meta 5.5 (2008). But the headset is for a combi disc 2007. (frame). There isn't one on it but the guy i bought it off told me it should be semi integrated.
Posted : 31/03/2009 7:48 pm
Ah, so no straight copy then.
Good luck, let me know how it goes ๐Ÿ™‚
Posted : 31/03/2009 9:06 pm
