Intentionally runni...
[Closed] Intentionally running a short chain?
Does anyone run their chain too short on the assumption that they'll not get full travel in lowest gear (assuming full travel is maximum chain growth).
Posted : 21/08/2017 11:34 am
Based on my experiences of accidentally running too short chains (either after cutting it or after someone else fitting one that can't get out of big/big), nope.
The consequences of bottoming out on it could be far more spectacular, so if you do decide to do this, please video it until you make the mistake!
Posted : 21/08/2017 11:36 am
Bikes with complicated axle paths (mainly those with suspension of the "two short links" variety" may achieve maximum chain length at less than full travel.
Posted : 21/08/2017 11:38 am
For what purpose?
Don't forget that you need extra slack to change gear, as the chain climbs up over the sprockets.
Is this a weight saving exercise? ๐Ÿ˜†
Posted : 21/08/2017 12:52 pm
I have set up my 100mm FS with enough chain to get nearly full travel in the big ring/big sprocket combo. So it is fairly slack. Has no ill effects though, no excessive chain slap or anything.
Posted : 21/08/2017 12:58 pm
Hell no, wrecked mech hanger and the time I tried to get away with it for one ride!
Posted : 21/08/2017 1:09 pm
