...which bits - if any - might need some grease or copperslip before installing them?
(Or I could wait and see which bits I installed last time won't come off, I guess......)
grease the BB threads and the axle and you should be fine ๐
I do all the bits - splines, threads (of cups & BB, chainring bolts, LH crank bolts, tensioner cap). Have a bit of a habit of topping up the grease in the bearings too.
No idea if it's right to do so
you dont want to grease the LH crank arm threads or preload cap (unless ya want them coming loose ๐ ) but make sure the BB threads have tons stops creaking
Thanks for this guys
I installed my new ones on the orange today, so that means the rocky should be quiet on Wednesday night, will you and Dave be out?
you dont want to grease the LH crank arm threads or preload cap (unless ya want them coming loose ) but make sure the BB threads have tons stops creaking
always greased mine and never had them come unintentionally loose.
you dont want to grease the LH crank arm threads or preload cap (unless ya want them coming loose ) but make sure the BB threads have tons stops creakingalways greased mine and never had them come unintentionally loose.
Me neither
Don't do what I did first time and over tighten the preload screw to a point of breaking it, it's just for pulling everything together, you want everything turning nice and freely.
