Info on 29 forks th...
[Closed] Info on 29 forks that are adjustable to 110mm
Are there any or do many 29er forks include the option of spacing so that you get 110mm? Especially interested in Manitou and Rockshox and older models as these seem to be cheaper. And, is it easy to do/buy the right spares for?
please thank you!
Posted : 09/11/2016 11:35 am
Older Rev's and Reba's could be spaced in 10mm increments. New ones need an air shaft swap or machining down.
Posted : 09/11/2016 11:38 am
Fox made plenty in 110mm as standard.
Posted : 09/11/2016 11:40 am
 cp
My Reba from 2012 - dual air will go in 10mm increments from 80->110mm.
Posted : 09/11/2016 12:26 pm
X Fusion Trace can be reduced down in 10mm increments, I think to 100m and would imagine the same can be done with their Slide model if you want 32mm stanchions rather than 34mm.
Great forks for the money.
Posted : 09/11/2016 12:43 pm
great, thanks guys. i will look out for these in the classifieds.
Posted : 09/11/2016 1:11 pm
