Inbred weight - are...
[Closed] Inbred weight - are there any obviously heavy bits on this build?
 tron
I've just weighed my bike, and was a bit surprised to see that it's over 30lbs, according to my possibly not that accurate Aldi scales.
It's an 18" Inbred, with most of the original Deore group left - front is now a double with SLX mech, but still HT2 Octalink & original rear mech & cassette.
Forks are a pair of coil / air Marzocchis - XC600s I think.
Stem is a cheapy, approx 100g heavier than it could be, but bars are protapers (275g). Saddle could also be a touch lighter as it's the original Inbred one (300g).
Front wheel is an original On-one built one, Reetard rim with a Dog hub, and the rear is a Deore hub with a 521. Tyres are 2.1 folding Nevegals. Brakes are Magura Julies, old low pressure variety.
Is there anything on there that's screamingly heavy? I can see a couple of hundred grams that can be shaved off cheaply - a new stem and saddle. Not keen on going for less than a 521 on the rims as I get to avoid ever having wheels trued ๐Ÿ˜†
As you may have guessed from the last sentence, I'm not too keen on spending huge sums ๐Ÿ˜€
Edit: shifters are windowless LX, seatpost is the original On-one twelfty, which again, is of sane weight.
Posted : 05/09/2010 6:30 pm
The frame.
Posted : 05/09/2010 6:33 pm
wheels and tyres, frame, forks...
Posted : 05/09/2010 6:37 pm
As above, the frame.
Everything is moderately heavy, but don't worry about it as long as it rides well. It's never going to be a lightweight bike.
 tron
That was pretty much what I was expecting. I built it to be as low maintenance as possible.
Nevegals feel positively lightweight at 580g a piece compared with steel bead Albert / RQ ๐Ÿ˜†
Posted : 05/09/2010 6:43 pm
The frames are pretty heavy - as heavy as a BFe I think (my BFe with Coil Pikes, SLX drivetrain and XT wheels is 30.9lbs).
My wife has a 14" Inbred with 100mm Fox Floats, Hope/X317 wheels, Conti Speed Kings, XT drivetrain, Deore brakes and Easton EA70/EA50 finishing kit and that's 28lbs.
My own 18" Inbred is built as a singlespeed with Pace RC31's, Deore brakes and Deore/X223 wheels and even that's 23.5lbs.
Posted : 05/09/2010 6:48 pm
I weighed my 20" inbred. No gears and _really_ cheap parts. 25.5 lbs
For you, change wheels or frame
Posted : 05/09/2010 6:58 pm
wheels would be the biggy I'd say. My 16" inbred (geared) is roughly 28lbs and there's nothing overly light on it.
It sounds like in your case its a lot of little things being a bit heavier than they need to all adding up!
Posted : 05/09/2010 7:08 pm
