Inbred and back pai...
[Closed] Inbred and back pain
Afternoon
I've a 16" inbred and I keep getting lower back pain, I've got the saddle pretty far forward and flat plus just fitted a 70mm stem. I'm 5'10 so the seatpost is v.high. My old 90's 18" Kona Fire Mountain has a short tt, more comfortable and easier to put the power on.
Sounds obvious but do you reckon my back pain's purely down to the inbred's long top tube or is the frame simply too small ??
doglover
Posted : 30/01/2009 1:25 pm
Too small, I used an 18" and I'm also 5'10". Also, if you've got the saddle pushed forward, this is going to make the small "cockpit" even smaller, no?
Posted : 30/01/2009 1:28 pm
Had thought the long tt was causing back pain so pushed saddle forward to compensate, guess I need to get a bigger frame.
Posted : 30/01/2009 1:33 pm
Yeah , 5' 10" is pushing it a bit for a 16" inbred. Probably fine if it's a playing around on bike but not going to be ideal for longer efforts.
Posted : 30/01/2009 1:42 pm
Ok cheers
Posted : 30/01/2009 1:44 pm
I'm 5'10 and have a 16" Inbred, 75mm stem, seat back on the rails a bit and it's spot on.
Had an 18" Inbred that felt like a gate before this though - not convinced you want the size up - I'd try one first.
Posted : 30/01/2009 1:49 pm
Yep that's good advice, will do.
Posted : 30/01/2009 1:52 pm
again 5"10 and loving the 16" 456
Posted : 30/01/2009 1:55 pm
Lower back pain also suggests that might need to strengthen your lower back muscles!
Posted : 30/01/2009 1:57 pm
Fair point, haven't much riding in recent months plus have a desk job that doesn't help. Tempted to get fitted properly by a professional - plus another good excuse to buy new bits/frame!
Posted : 30/01/2009 2:06 pm
 ski
Yep, I am 5-10" on a good day, had both a 18" geared and 16" SS Inbred for a while, I sold the 18" in the end and kept the 16".
For all day simple trails, the 18" was fine, but the 16" feels some much more fun on the trickier, tighter stuff.
BTW, similar set-up as Mrblond, seat back on the rails a bit, 80mm onone stem.
Posted : 30/01/2009 2:15 pm
Got a 16" slidey and am 5'7". 75mm stem inline post forward on rails and a good stack of headset spacers on a 130mm fork. Seatpost is a long way out and I don't find it easy to loft the front compared to other bikes, but blimey is it stable through rock gardens.
Only back pain I get is when I've been lifting it over stiles alot ๐Ÿ™‚
Posted : 30/01/2009 10:53 pm
[i]I've got the saddle pretty far forward and flat plus just fitted a 70mm stem[/i]
Bit confused here as your saying you think you need a bigger frame then say you put a short stem and moved the saddle forward.
fwiw I'm 5'9" and on a 16"...90mm stem, layback seatpost. Fits well.
I did get lower back pain but found that reducing the height of the front (low stack height steerer, low risers) and getting the weight slightly more on the the arms (and therefore the front suspension), it took some of the weight off my rear reducing long distance back pain.
Posted : 30/01/2009 11:04 pm
You need to get your workplace looked at - a proper assessment of the desk, chair etc. It is all related.
Posted : 31/01/2009 7:56 am
