Is there anyway to tell visually if particular dropout inserts will fit in a particular frame?
The ones below look like standard Paragon Machine Works insert type, but are marketed as Brother Cycles specific.
The frame I may want to fit them in (Sonder Broken Road) also looks to have Paragon dropouts, but again they are not advertised as such.
I actually have a Soma Wolverine with IRD dropouts, which doesn't officially take Paragon inserts, but unofficially, they are exactly the same -- so that's what I'm running. I wonder then if most sliding dropout inserts that look basically the same (which certainly isn't all of them) are indeed the same.
https://www.brothercycles.com/shop/accessories/big-bro-rohloff-dropouts/
If I recall, stooge and brother cycles share the same so I think there is so crossover for sure
Doesn't answer your question though
