ideas on how to rai...
[Closed] ideas on how to raise bar height on c'dale m1000 with 1 1/4 threaded headset?
basically it uses a 1/4 quill stem of which there areย  very few options and none I've seen with any decent height adjustment .Also the stems all seem to have old style non faceplate clamps meaningย  a high rise bar can't be used as it won't thread through .. Ideally I really want an ahead quill converter but none available as far as i know in that size.ย I don't want to change the fork so any ideas or suggestions much appreciated .
thanks
Bill
Posted : 20/02/2018 10:40 pm
Would this work bud?
http://item3d5703022f:m:mb05nJjxZ01Cz2bvFbGuwVg
Posted : 20/02/2018 11:21 pm
An 1 1/4 Ringle Zooka was made. Mostly 0deg rise though. You could try a pair of 22.2mm bars and a shim, you will be able to thread the riser though a non removable face plate stem. What stem is fitted?
Posted : 20/02/2018 11:27 pm
 JoeG
^ was what I was about to say 👍🏼
Posted : 21/02/2018 1:42 am
Original stem is control tech.thanks for the quill link..may try and make one out of an old stem! couldn't get poopscoops link to work.cheers.
Bill
Posted : 21/02/2018 10:33 am
We used o get our risers in that type of stem by taking the bar clamp bolt out, and thread it in to the threaded part the wrong way round.
put a penny between the gap and the bolt will push against it, opening the clamp up enough to wiggle the curves or the bar through.
Posted : 21/02/2018 12:48 pm
Do you not just loosen the stem off, lift it and then retighten it? That was about the only benefit of threaded steerers.
Posted : 21/02/2018 1:10 pm
loosening the stem is not advantageous as they all tend to have hardly any extra quillย  length to extend. I know that technique to open stems up a bit wider but with a decent rise bar ( 3 inches ) it isn't possible without possible irrevocable damage.
Posted : 21/02/2018 8:13 pm
