My firm's Cycle to Work scheme is an exclusive deal with Evans Cycles. "How bad could it be?" I thought. Ordered a nice new Trek Checkpoint SL5. They txt'd me to say it'd be ready in a couple of days. Then they called the next day to ask when I'd like to come and get it. So far, so good.
So I drive to pick it up, Thursday lunch time. It's there, ready and waiting and the pleasant sales guy sort of sizes it up and makes sure I'm happy. It's a cracking looking bike and I happily wheel it out of the shop to my car.
Then I pull the right-hand brake lever... and the rear brake comes on.
FFS.
I take it back. A different sales guy is very apologetic. Takes me round to a young mechanic who looked like he didn't give a shit, but we agreed that it'd be sorted by 0900 the next morning. Inconvenient and not a great start, but solvable.
So I come back next day at 0900. Bike is ready. Brakes feel... OK at the front, a bit soft at the back. It'll need a bleed but I couldn't bear to leave the bike with them any more, so I take it home.
Saturday morning. Time to tweak the fit. Bars need to be lowered. Remove stem top cap, which screws into the top of the expander bung (the fork has a carbon steerer). But hold on, the bung's bolt is just going round and round... Manage to get it out. The rest of the expander has fallen to the bottom of the steerer tube! So only the stem pinch bolts holding the steering together. FFS.
After fixing that and checking that every other bolt was tight, I go for a short ride. All good for a couple of miles, but then the front shifting is all over the place. On closer inspection, the cable isn't routed correctly into the derailleur so I'll need to have a go at that, too (and GRX front derailleurs are rather finicky, according to this: https://si.shimano.com/#/en/iDM/GAFD001
It's one thing to pick up a new bike that needs a little TLC before it's ready for you. It's another that could have caused an accident. Unimpressed.
I don’t trust anyone with my bike tbh but even less so an evans/halfords etc mechanic. I’d have factored in the fact I needed to do a full check over of the bike when buying it from there. It shouldn’t be that way when buying from there but unfortunately it can be.
Hardly a horror story though.
Meh, disappointing but hardly 'horror story'....I was expecting worse from the thread title
Tamest.
Horror.
Story.
Ever.
It is always the stem pinch bolts holding the steerer together. The top bolt is only to tension the bearing. That doesn't excuse the incorrect fitting but you weren't in danger.
I used to work at an Evans store and saw some pretty horrific practices going on by the mechanics. One time a mechanic scratched a carbon road fork and decided to colour it in with a felt tip. The customer noticed straight away and ended up getting a new bike as compensation. Both mechanics in the store had zero cytech qualifications.
I am assuming part 2 of the story has some horror in it. When will you be posting it, I can't wait?
ive had about 7 norcos from Evans. Had a good run.
Isn't the expander there to stop the carbon steerer from being crushed by the stem, or is that being overly paranoid?
Thats hardly a yard stick! Had a headset pressed in at the local shop, mechanic is apparently very good, I dont think the plastic bag the frame was wrapped in was supposed to be pressed in with the headset, then trimmed with a blunt knife!!!
On closer inspection, the cable isn’t routed correctly into the derailleur so I’ll need to have a go at that, too (and GRX front derailleurs are rather finicky, according to this
the 2x fans will be here shortly to tell you that front mechs are perfect, and the easiest thing in the world to set up.
1x for life
Shut it you slag 🙂
3x for life 😉
I bought a Trek road bike from Evans Castleford about ten years ago - this was after Trek mandated store collection of their bikes so they would be built up safely and correctly...
I went to pick it up and rode off through the car park to my car and the stem to steerer bolts hadn't been tightened. The first and last time I want to experience that on a bike!
I have since bought other bikes from them online and other stores, and they have been fine!
The basic build is done by Trek - all Evans do is unbox it and sort of turn bars, put wheel in, check gears, pump up tyres.
Guessing from the wrong-way-round brakes that it's a European import that ended up in the UK by mistake. Although to be fair, the mechanics should have picked up on that and changed them - maybe they thought it was a specific request?
My mum bought a bike from Evans and has been riding it. Now I'm worried!
Guessing from the wrong-way-round brakes that it’s a European import that ended up in the UK by mistake.
Brought in due to crazy uk demand
I went to pick it up and rode off through the car park to my car and the stem to steerer bolts hadn’t been tightened. The first and last time I want to experience that on a bike!
OK, that's worse.
That doesn’t excuse the incorrect fitting but you weren’t in danger.
You're assuming those bolts were tight enough... They didn't feel like 5NM when I loosed them...
If I'd titled the post "I have to share my Evans lax mechanic story" none of you would have read it.
3 bikes from Evans Nottingham, absolutely no problems, so I'm not exactly quaking as a result of this story.
Never had a problem with my localish Evans in Maidstone.👍
If I’d titled the post “I have to share my Evans lax mechanic story” none of you would have read it
Correct, and now there's 5 mins of my life wasted.
Apologies to anyone who read this due to me bumping it back to the top of the forum.
Well I enjoyed it 👍🏼
I went into Halfords (everywhere else was shut) to see if I could get any olives/inserts for Tektro hydraulic brakes as I need to shorten/re-route a hose, there were none available online anywhere, and I know they sell a lot of bikes with Tektro brakes...
The 'mechanic', who was in the process of building/prepping a bike for sale, had no idea what I was on about, I had to pull the cover back on the brakes on a stock bike to show him the shroud nut and explain what the parts were. Needless to say, they didn't have any.
I would only trust 2 local shops (out of several) to do any work for me.
3/10 for horror story.
Haha,
Similar happened to me previously at Evans - just said give me the damn bike and rode it down the street to mech I trusted.
I think the real problem is half the mechs at Evans are roadies - can’t MTB work like droppers / hydro brakes... Even in a store you can chat to a few people, once you find anyone into MTB properly you will find they are better than the mech. Sales guy in London once actually dialled my suspension pretty well 😂
May not be a horror story for most people on here but for a normal punter who knows nothing about bikes, these things should not be happening.
Nope, probably half of the bikes we get from Trek need the brakes swapping before they go out.
Which is a real pain when you then need to redo cabling, retape bars and bleed brakes.
0Which is a real pain when you then need to redo cabling, retape bars and bleed brakes.
Yep!
I found that Halfords mechanics had decided to take off my Ck headset with a flat bladed screwdriver. Needless to say they snapped a bit off. Then expected me not to notice.
Kind of feel that way too. With one exception, who has a number of cytech qualifications.
I trust Cyclopedia and Sunset in Cardiff. Or I would, if I needed them 🙂
I had shocking service from Evans 15 years ago and haven't been back since.
Having said that I've worked in the trade and every so often someone makes a mistake somewhere, no matter how good they are. Just like the rest of life.
It may not be a horror story, according to the online experts, but it's ****ing shocking!
They are hopeless, imagine how many non-experienced riders are going round on badly built bikes.
I had similar from Halfords a while ago, they gave me the checklist, with the (warranty replacement) bike, like everythings built and checked and the brake blocks rotated in the calipers! Shocking.
But yeah, horror story would involve actual injury according to STW experts, no doubt.
Agreed @DezB it's why i've dropped my sub the mag/company doesn't deserve it, the forums mostly an absolute cesspit of trolls, swinley elitists and racists
STW could follow Pinkbike who they claim to be bigger than and get rid of the trash but, that doesn't drive traffic/ads
*edit and allowing titaniumtit back on here as Tdog after he's scammed the shit out of people for 10+ years on here and Pinkbike (where he has a permanent ban) but, again its traffic
Blimey, I'm not sure I'm not the same forum as you mehr?
And yet, here you are.
Shouldn't say this as Evans sponsors my club. But after sending a new bike back with a dodgy rear triangle they organised a new frame and rebuilt it. Went to pick it up and when wheeling it out of the shop I realised the steering was very stiff, the headset wasn't fitted properly.Took it straight back into the shop to show their mechanic. He said it was fine! Er, no! "Yeah, its fine, you just need to use the muscles in your arms to turn the bars". His exact words. I couldn't stop laughing, at his expense. Not really a stab at Evans, I've bought loads of stuff from them and been very happy, but they do seem to employ the odd random.
it’s why i’ve dropped my sub the mag/company doesn’t deserve it, the forums mostly an absolute cesspit of trolls, swinley elitists and racists
WTF is a Swinley elitist? As for cesspit and racists, this is the tamest place on the whole of the internets.
I was wondering that...
@mehr - wouldn’t worry about really, most of them think they’re comedians, much like most of the youtube commenters and Twitter bores... where they get their witty ideas from usually. Imagine if they could post an amusing gif along with their hilarious thoughts.
Swinleytist?
I'm also genuinely interested. As one of the only three trails that exist in the South East (along with Peaslake and the woods behind the Nationwide in Swindon, obviously) I'm wondering how Swinley won this accolade?
I got an Arkose from Evans. It was tiptop.
Mehr if you think we are all spunknozzles why don't you just bugger off?
Ooh I just learnt a new word! Evey day's a school day 🙂
I'll second that. I am on a rugby forum that has been totally ruined by trolls and racists - just 3 of them but because of slack modding they have driven 3/4 of the posters away
Despite being on the wrong end of modding and trolling on here I would say by and large this place is pretty good from that point of view
Me thinks Mehr has been on the meth. Meh, indeed.
The problem with posts like this, whilst acknowledging that badly built bikes have the potential to cause serious injury, are...
Slagging off a whole chain because your local branch has given poor service is not necessarily fair (although the chain should do more to improve the poor performers)
It's likely that other shops have similar issues, but are less likely to get called out on the internet, mainly because most folks would never have heard if them.
You are more likely to get a result by taking up your grievances with the shop or, if necessary, the headquarters of the chain. After all, if you just walk away and fix it yourself, the shop have no feedback and are not likely to improve.
Anyway, I hope the bike is now sorted and you are enjoying it - I did like the look of them, myself, but need to buy a TARDIS shed first
I always feel obliged to stick up for my local Evans in Edinburgh, they gave me some pretty good service in general and put up with my outrageous abuse of the Specialized saddle comfort guarantee thing with good grace.
When I worked in a shop (a long time ago) mistakes happened. I know we all took pride in the service we offered, we all wanted every customer to go away happy, whether it was a £300 or £3000 bike, but things still slipped through the net. Possibly my worst mistake was letting a bike go out the door without stem bolts tightened due to a last minute mudguard fitting requested by customer on a busy Saturday, both me and mechanic thought the other person had tightened stem bolts. I know the shop in question now has a pretty thorough checking process before bikes go out the door, but the problem with that is it completely robs you of the ability to quickly help customers with mechanical stuff, shop floor staff aren't allowed anywhere near tools, mechanics need to check over everything as it comes in and out of workshop, etc. etc.
Funnily enough, the most common complaint about our shop was the waiting times for the workshop...
Ordered a bike from evans once, went to pick it up, "err sorry but the mechanic has stripped the pedal threads and we need to wait for a new crank arm from canondale". Never went back after that.
The basic build is done by Trek – all Evans do is unbox it and sort of turn bars, put wheel in, check gears, pump up tyres.
When I was a mechanic we had a post delivery inspection which included truing and tensioning wheels.
It were all better when I were a lad. No respect etc. etc.
The last few times I've bought bikes new I've managed to persuade the shop (Halfords and Edinburgh Bicycle being the last couple) to just give me the bike boxed up so I could put it together myself. I've had issues with both places previously - nothing actually dangerous, but stuff like gear indexing and brake set-up etc.
Oh I dunno. The chain is responsible for setting the standards and training the staff.
As covered later in that post....
It's been full of smartarses for as long as it's been around. I remember it being so from 15 years ago. I deleted my account and have only just started nosing back on. I've not noticed racists though??
