I bought a cheap i ...
[Closed] I bought a cheap i spec b shifter....
I bought a super cheap i spec b shifter without the clamp.....its an xt 11sp.
As i dont know much about this, the ither house bikes have 11sp xt i spec 2 that mounts to a little sleeve that pushes under the brake lever clamp. The other has 11sp with a bar clamp and brake clamp seperate.
It appears i cant do anything to mount this shifter. Does anyone have any suggestions?
Thanks
Ian
Posted : 04/04/2020 6:00 pm
There are ways, but it won't be a cheap shifter by the time you're done.
Problem Solvers make an adapter, I think.
Posted : 04/04/2020 6:26 pm
Contact LBS with a Madison account. I got the bits for about £9.
Posted : 04/04/2020 7:32 pm
Download the diagram for the shifter from Shimano tech docs.
Get the part number you need
Google the part number and chances are SJS cycles will have the part you can then order.
Posted : 04/04/2020 7:42 pm
That sounds great.
Thanks
Posted : 04/04/2020 7:44 pm
Had similar with XT 10 speed and found what I needed on bike-discount.de
Be careful though, I needed to order 2 separate parts to swap I-spec to bar mount.
Posted : 04/04/2020 10:49 pm
