Hunt trailwide hub ...
[Closed] Hunt trailwide hub service,,, how?
Need info on how to service them I may have missed it but can’t seem to find it on hunt site, YouTube etc.
250miles/2mnths old and the free hub (pawls/ratchet?) started skipping under power last night on the way home.
Last week I found that the end caps had loosened after a couple of wet night rides and I’m hoping that a bit of Shoite has got in and it just needs a clean.
Hopefully sort the problem myself rather than mess about sending wheel back under warranty.
Any advice much appreciated
Posted : 28/10/2019 8:29 pm
That new I think I’d probably warranty it
Posted : 28/10/2019 8:39 pm
True, but,
I’m concerned that it may be dismissed as user error.
If end caps loosening has caused ingress of shoite then it could be argued that it is my fault.
If I can service it and all is well then it’s a problem avoided.
Posted : 28/10/2019 8:53 pm
They're just rebadged Novatec hubs, IIRC, so if you search for how to service those you might find something.
JP
Posted : 28/10/2019 9:40 pm
End caps shouldn’t loosen though. Hunt are very good for CS, ping them a FB message now and you might even get a response by the time you head for a snooze!
Posted : 28/10/2019 9:44 pm
Just figured out how to dismantle hub, it’s not looking good.
Have pinged hunt, will up date after contact.
I don’t do Facebook.
Posted : 28/10/2019 10:36 pm
A mate had the freehub fail on his Hunt wheels.
Hunt sorted it quickly when they looked at the hub as it had a manufacturing defect.
Posted : 28/10/2019 11:26 pm
