Bike Forum
1
Posts
2
Users
0
Reactions
170
Views
Hi.
I run the Hunt Enduro Wide wheelset. I think the rear hub needs some attention so looking to give it a bit of a clean out and regrease. Are there any guides on how to remove the freehub etc? What sort of grease do you use inside the hub.
Any tips much appreciated. Thanks.
Posted : 05/07/2020 8:45 pm
I suspect there's a guide on the Hunt website somewhere, but its basically 2x 17mm cone spanners to undo one endcap off the axle, pull the axle out, pull the freehub off. Clean, regrease, reassemble. I doubt it makes much difference what grease you use, so long as you don't go overboard.
Posted : 05/07/2020 8:58 pm
