Hub and wheel exper...
[Closed] Hub and wheel experts (Hope)
I have Hope Fatsno Hubbed wheels and may want to get the rockshox bluto forks when available but it needs to be a 15 mm by 150mm Maxle
Can I make some adapters that are 7.5 mm wider for each side or is it more complex than that
Posted : 28/05/2014 7:02 am
No, Hope are bringing out a hub for this fork so go that way, if you ad adaptors they won't take the extra stress and risk damaging your fork and hub. I imagine it will void any warranty on both also. We're stocking both forks and hubs shortly.
Posted : 28/05/2014 7:11 am
Adaptors will also move your rotor away from the fork, probably too far for the caliper to align with.
Posted : 28/05/2014 7:17 am
and that....
Posted : 28/05/2014 7:21 am
Cheers guys but just found this on MTBR
[url= http://forums.mtbr.com/fat-bikes/bluto-hope-135-hub-hack-915365.html ]Bluto + Hope Fatsno [/url]
Posted : 29/05/2014 7:22 am
Looks like he's had an offset brake mount machined up too (from the pics, didn't look at the words).
Posted : 29/05/2014 7:42 am
 Andy
Thanks Trout this answers my exact same question. Wasn't aware of the White brothers adaptor ๐Ÿ˜€
Posted : 29/05/2014 8:00 am
Me neither but my disk is 200 mm so might need to make a disk spacer for the hub instead.
Will be spinning up the Lathe over the weekend
Posted : 29/05/2014 8:07 am
Did you make adaptors Troutie?
Posted : 18/12/2014 2:57 pm
Old thread brought up, but hope make their own spacer to bring a 135mm/142mm front fatsno hub to 150mm to accommodate a bluto. This comes as a kit and includes a disc spacer too. Any hope dealer should be able to get you one.
(I know they make it, as I have one)
Posted : 19/12/2014 12:00 am
