HR Zones on Trainer...
[Closed] HR Zones on Trainerroad
I've done a session on Trainerroad tonight, and when looking at the data it says I spent no time in VO2Max
I'm 43 so roughly I may be able to get high 170's but the range it is suggesting is Low 173 to High 220 !
I will never get near 220, pushing hard I get to about 173, and yes I am sure I could potentially push a little higher, but 220 erm no.
So how do you reset the max heart rate?
Ta
Posted : 16/08/2017 9:49 pm
Do a heart rate test and enter the result into TrainerRoad? Or am I missing something?
Posted : 16/08/2017 10:28 pm
No idea about Trainerroad, but I'm also 43 and have had readings of 188bpm iirc, a couple of times this summer while climbing local hills.
 Haze
You'll want to set your LTHR threshold value before you can set zones.You can establish this from the 20 minute test if you haven't already?
VO2 is something like 106% of this value iirc
Posted : 16/08/2017 10:49 pm
Ah all very logical. I've not done the test for a good few years (when Trainerroad first came out) quite a bit older now ๐Ÿ˜†
Posted : 16/08/2017 10:53 pm
