How to remove tubel...
[Closed] How to remove tubeless sealant from tyres?
Hello,
Got some spare tyres I'm going to put on an innertubed set up.
Whats the best way to remove the dried up/ semi dried up sealant?
Do I even need to? There's quite a bit in there I guess but should it effect the tube?
Posted : 04/07/2016 10:23 am
Just leave it in place. No need to remove unless you're a weight weenie
Posted : 04/07/2016 10:24 am
Quick scrub with a nail brush to remove the loose stuff, then leave it. Seems to dry up further with a tube in there (I guess the friction grinds it up).
Just be aware the tyre is probably full of thorns, grit, and everything else that would have caused a puncture but the sealent stopped, be prepared for a lot of punctures in the first few rides as you find them all!
Posted : 04/07/2016 10:27 am
I use a Dremel with a nylon brush. It looks like s small chimney broom.
They heat up though the friction and throws off the gunk better than anything else I've found.
Posted : 04/07/2016 10:32 am
The best way to remove the sealant is to toss it in the trash when the tyre wears out or is punctured beyond repair.
Posted : 04/07/2016 10:41 am
try wearing a nice thick marigold glove and lots of back and forward rubbing. Then get the vacuum cleaner in there to pick up all the little bits.
Posted : 04/07/2016 10:51 am
ooooerrrr!
I'll give all of the above a go, cheers.
Posted : 04/07/2016 10:55 am
