How to get a track ...
[Closed] How to get a track from a wahoo elemnt bolt?
I've been using an elemnt bolt on the road for a while but yesterday just started using it on the mountain bike.
How do i export a track from it? I want to get a tcx or gpx file that I can open in viewranger or backcountry navigator and overlay onto an ordnance survey map so I can use it it to track new bits of path I explore.
In the element app I can only share a .fit file which viewranger and backcountry navigator won't open. Komoot only allows a .fit download. And ridewithgps says I have to be a paid member to download a tcx or gpx from the fit file sync from the elemnt app.
Is there a way to get a track from the elemnt via the app without having to join and pay for more 3rd party apps?
Posted : 14/07/2019 10:44 pm
I've used this Converter with success before.
It's meant for combining files into one, but if you just upload one file, you can then download it as a GPX.
Edit: Ah, missed you want it via the app. That link is probably less helpful then!
Posted : 15/07/2019 11:48 am
Do you upload to strava?
If so just open the activity in strava, add /export_tcx to the page name in your browser and it will download the txc file for you.
Posted : 15/07/2019 11:54 am
Not currently uploading to Strava but I'll try that, Thanks.
Posted : 15/07/2019 12:05 pm
Also an online converter at Gpsies. You have to register, but it is free. https://www.gpsies.com/
Posted : 15/07/2019 12:14 pm
Also GPS Babel
https://www.gpsbabel.org/
Posted : 15/07/2019 12:40 pm
You probably know this already, but if you synch your Elemnt with Komoot you can download a GPS direct from the Komoot website.
Posted : 15/07/2019 2:04 pm
I was using komoot but just the app, didn't think of trying the website for a gpx download. Doh!
Thanks Badlywireddog!
Posted : 15/07/2019 2:16 pm
No worries.
Posted : 15/07/2019 3:17 pm
If you already sync to ridewithgps, you can simply click on the completed ride and then go 'copy to my routes'. You can then download the route as gpx/tpx.
Again, you need a desktop to do this.
Posted : 15/07/2019 5:15 pm
Just open the ride in the app and tap the share button. Gives you the option to export the GPX or FIT file.
Posted : 15/07/2019 5:28 pm
