How tight should a ...
[Closed] How tight should a valve core be tightened....
Still got a tiny, tiny leak at 150psi with the shock attached (I can watch the needle on the gauge drop very slowly, say 5psi in 20 seconds)
I can set my sag ok, but would like the comfort of knowing its tight - but am afraid of breaking it off in the shock.....?
Posted : 11/06/2012 3:35 pm
does it leak with the pump not attached - when the pump is attached the valve is held open usually is it not?
Posted : 11/06/2012 3:39 pm
No, it doesn't appear so. Just that in the past whenever I've screwed the pump on they've never leaked - I've tried multiple pumps as well and its definataly the valve - this is the new core after the old on did the same :-/
Posted : 11/06/2012 3:49 pm
its not the valve then if it doesn't leak when the pump is off it - the pump holds the valve open.
Posted : 11/06/2012 3:56 pm
Then.... what?
Posted : 11/06/2012 3:58 pm
ignore it. Pump to required pressure, take pump off. If it holds air you are fine
Posted : 11/06/2012 4:02 pm
Okay.
But just out of interest, whats the answer to the original question? Hand tight, or as hard as you can turn it with 2 hands tight but dont put a pair of pliers on a valve core tool tight?
Posted : 11/06/2012 4:06 pm
I always just do them up with the tool held between two fingers - you are tightening down onto a rubber cone so it does not need a lot of pressure
Posted : 11/06/2012 4:09 pm
 LoCo
Thumb and fore finger, 'nipped' ๐Ÿ˜‰ or about 1/2 turn before it snaps ๐Ÿ˜ฏ
Posted : 11/06/2012 4:10 pm
Are you over tightening the pump onto the valve? Should only be half to one turn after you hear it start taking air,
Dip the shock in a sinkfull of water, you'll see if any airs leaking then.
Posted : 11/06/2012 4:14 pm
