How the 'ell d...
[Closed] How the 'ell do I get the old bearings out my hub?
Firstly it's a 20mm front hub, a Rocky Mountain Carbon to be precise.
I've tried tapping, pulling, and even turning the spacers on the outer side of hub, you know the 110mm spacers.
Also, I see there's a gap inside the middle of the hub in the centre of a rectangular shape.
I tried to tug on it with a bit of thick metal cable but to no obvious affect. ๐Ÿ˜ฎ
Don't really want to buy a new hub and spokes to rebuild with as I need this wheel sorted before this Wednesday before a bike trip.
What's STW's way of dealing with an o.e.m. hub that won't budge. โ“
Posted : 22/08/2010 7:53 pm
Precise about what? Is the hub a Rocky Mountain Carbon cos there isn't a bike just called a Carbon in their range.
Do you have the replacement bearings to go in?
Posted : 22/08/2010 8:01 pm
It's an actual Rocky mountain carbon hub.
No, mainly because I do not know what size it requires for a new set until I get the old set out.
Hope this clarifies.
Posted : 22/08/2010 8:35 pm
have you taken the caps/spacers off? you should be able to see the bearing & therefore number then. i wouldn't personally be popping bearings out unless i had new ones to replace them with immediately as a wheel with shot bearings will still be of use.
to pop the caps/spacers usually use the end of the 20mm axle and insert a few mm into the end and lever out. same on other side. to get bearing out use a long flat head & a hammer. there might be a spacer between the two bearings that will allow you to shift a little to seat the head of the screwdriver on the bearing. you will probably need a bit of force, but beware that this method can sometimes split the bearing races and you could be left with the inner race out of the hub and the outer left in. then you are fekked! but it's never happened to me yet. seat new bearings with an appropriate sized socket (one that will force the outer race in & not damage the seals.
easy job once you've done it the first time.
Posted : 22/08/2010 8:46 pm
Thanks for that peachos, - I'm not doubting it's an easy job with the sort of hub that allows for swapping of bearings.
Just that the cap spacers won't budge even after trying to tap out.
As for the axle idea, I have not tried that but really cannot see it happening.
Really want to know what the rectangular shape gap inside the centre of hub is there for โ“
Posted : 22/08/2010 8:59 pm
without looking at it hard to say mate. have you tried RM - they may have tech manuals on the website...
Posted : 22/08/2010 9:12 pm
I've looked on the website, cannot see diddly squat.
RM don't even supply Silverfish with the bearings or spares for their own components.
๐Ÿ™„
Typical!
#EDIT#
I have been trawling google searches for RM 20mm hub spares etc etc but to no avail.
Posted : 22/08/2010 9:15 pm
I have a Hope hub exactly as Peachos describes. It is ****ed. Damn bearings!
Posted : 22/08/2010 9:58 pm
Trouble is, I have had 1 ride on it so far.
Mind you it had 2 seasons on/off use on it before I got it but will be sorted out no doubt.
Thanks folks for the advice and info.
Honestly thought it would of been doable to swap to new bearings. Oh well, looks like a fairly nice hub aswell for stock kit.
๐Ÿ™‚
Posted : 22/08/2010 10:07 pm
Done now.
Had to have a punch used on it to push the end caps out and off to get to the bearings.
thanks Peachos for your initial help.
๐Ÿ™‚
Posted : 23/08/2010 6:48 pm
paulrockliffe - Member
A bearing puller should easily sort this out (local garage or engineer shop will have one or just buy one), or a dremel if your careful, at worst talk to Hope.
But blaming the bearing is wrong, IME it's your fault for letting them get into that state, if you'd changed them when they started to get play in them, they shouldn't have fallen apart when you tried to knock them out. ๐Ÿ˜›
Posted : 24/08/2010 8:59 am
Anyone know of any places that stock 6044's and can deliver sharpish!?
Zippy? ๐Ÿ™‚
Posted : 24/08/2010 12:23 pm
LOL - you really don't know paulrockliffe. he was taking the piff out of me last night for cleaning and repacking a some headset bearings ๐Ÿ™„
Posted : 24/08/2010 12:26 pm
onceinalifetime - Member
BETD are a good bet!
Posted : 24/08/2010 12:27 pm
Call SMB in Oxfordshire on 01993-842555 - They do every bearing and deliver same day, oh and they take paypal too so there's no need to register/swap credit card details etc.
Posted : 24/08/2010 12:31 pm
Bearing 6044
Dimensions 220 x 340 x 56
Are you sure it was a 6044?
Posted : 24/08/2010 12:36 pm
Thanks peachos and skyliner, - Will do, am on the case.
Onza, it does state on the outer seal 6044 and have been informed the lbs's round my way don't hold stock of them as it's not a common size to use.
Interesting?
Posted : 24/08/2010 12:42 pm
I'd be surprised if it was anything other than a 61804 (also called 6804)
Posted : 24/08/2010 12:45 pm
I'll go check, back in a mo!
Posted : 24/08/2010 12:48 pm
Would you adam and eve it, it's a ''6804''
The 8 ''looked'' was pretending to be a 6 for a while ๐Ÿ˜›
Posted : 24/08/2010 12:53 pm
SORTED!
Thanks folks ๐Ÿ˜€ thumbs up.
Posted : 24/08/2010 12:57 pm
for future ref, simply bearings are a good company to deal with
Posted : 24/08/2010 1:00 pm
I normally use the Hope ones from Wiggle. Less than a fiver a piece I think and the last ones were SKF. Not seen them cheaper anywhere else.
Posted : 24/08/2010 1:06 pm
