How permanent is a ...
[Closed] How permanent is a tubeless plug repair ?
I put a plug in a ghetto tubeless tyre on Sunday.
One of these. http://www.wiggle.co.uk/p/cycle/7/Innovations_Tubeless_Patch_Kit/5360018216/
It lasted the rest of the day OK, but it seemed a bit soft the next day.
The bike's not at home, so I haven't had a proper inspection yet. It might have lost all its sealant, it certainly lost a lot at the time, or there might be another puncture, or maybe it's just the valve leaking.
It's only the second time I have used one of these plugs. Last time, as far as I remember, the repair lasted the life of the tyre.
How permanent do people usually consider plugs ?
Are they fit and forget, or are they a get you home bodge ?
Is it best to stick a proper patch inside the tyre as soon as possible ?
Posted : 13/10/2010 2:48 pm
I tend to leave them in until the next time I'm changing a tyre and then fit a proper tyre patch on the inside. - I do trim them so thay are 'below' the level of the tread.
Also, top the sealant up a bit via the valve.
Posted : 13/10/2010 2:50 pm
my front tyre currently has 2 patches that i superglued on the outside. try it, works fine! both were trailside repairs, i carry a old piece of sidewall and a small tube of superglue in my pack.
Posted : 13/10/2010 2:52 pm
Yeah, I was going to top the sealant up anyway, there was loads of it all over the road and my legs.
I've used heavier patches, the same ones I use on my Land Rover tubes, to patch damaged tyres before.
I'm a bit concerned because I'm riding Oktoberfest next weekend so I don't want to take any chances. If I was just commuting I'd put up with a possible slow puncture.
I guess I ought to just get the bike home and dunk the tyre in a bucket to see where the air is escaping from to see if it is the plug or not.
Posted : 13/10/2010 2:56 pm
