I've got some 700c x 32's I want to make tubeless and some 29'er x 2.25" I also want to do.
Anyone know how much sealant I should add? I'm thinking about 60 ml for each 32 but no idea about the wider tyres.
100-120 for 29ers, more if 2.6+
1 stans scoop in the 700c and 2 scoops in the 29er. So what you said and double for the 29er.
Am I doing something wrong here? My tyres are so tight on the rim that I can't get my lever under the bead. Trying to warm them up on radiator but not really helping so far.
Unseat all the bead on both sides and push it into the central channel on the rim. More room then.
That's what I'm having trouble doing though.
Edit - ok now.
60ml for running procore, 75-90ml if not, like it says on the box. (for MTB, not sure how much for road, half that sounds reasonable.)
Oh ok. I assume this is the 700c? I have had to use a big dh type tyre lever before on new road tubeless tyres. Thinner tip, metal construction and lots of leverage.
Get valves with removable valve cores, then add sealant via the valve. Much easier than popping the bead on the tyre off the rim.
(EDIT: maybe that's what you're doing, I'm not sure).
One of the tyres just won't seat. It's lubricated with soapy water. I don't have an electric pump. Anything I can do?
You can try the tyre lever method.
There's a youtube video which I can never find.
Put a tyre lever under the bead as though you were going to pop the tyre off. But then instead of levering all the way up, just lever until it's perpendicular to the rim.
Then slide it around the rim until it gets so tight that you can't slide it any more. That sliding lifts the bead up onto the "shoulders" of the rim, which is where you want it.
Repeat on the other side.
Then have another go at inflating using your trusty coke bottle inflator (or a track pump and super-strong arms).
This has worked for me on a number of tyres that really didn't want to know.
I give up on it. The tyre is so tight it refuses to slide off the middle of the rim and the levers are useless, If I'd known it would be this much of a ball ache I would have stuck with tubes.
Remember Robert the Bruce & the spider.
I got one of these - I've had no bother with any tiyres since 🙂
https://www.upgradebikes.co.uk/Catalogue/Workshop-Tools/Proform/Proform-Tyre-Tool
Well the one which won't seat will seat with a tub inside but not until about 35 psi, and I noticed the rim tape is a little folded over on itself or crimped so it probably need changing.
Also the wheel that did seat leaks at about 30 psi. Seems maybe it's not properly seated?
Yeah the air in the tyre that seated ok actually escapes between the valves and the valve flange in the rim, like the seal isn't good past 20 psi.
If you use Stans Raced Sealant you can't put that in through the valve as it clogs it.
Sounds like the tape is nicked on the leaking wheel too and the air is making its way to the valve hole. I would re - tape that one too.
I always put a bit more than what the manufacturer recommends, that way if you get weepage it doesn't really matter.
OP - possibly daft question, but are you using proper tubeless tyres on tubeless (ready) rims and have you taped (tubeless tape) the rims etc? Sorry, had to ask 🙂
Yeah they are advertised as tubeless ready, they are Kore Realm 2.7 and the tyres are WTB TCS. I used some Stan's valves but they didn't seem to seat too well in the flanges.
Even with a home-made gasket I can't get a seal past 20 psi around the Stan's valve. It's like maybe the flange is too small for the rubber wedge to properly seat in? Either way my experience so far with tubeless is not good. Seems total garbage.
The 700 c x 32 c is impossible to seat as well. Like trying to pump up a sieve. Just cant get any pressure at all to work with.
3 wheels, 3 failures. Can't understand why I even wanted to go tubeless.
Do you have sealant in ? The valve won’t seal without it. Also, without a tyre booster or compressor it isn’t always possible to get the tyres to seat. A Booster costs about £40 and is a godsend for this. I can rarely get tyres to seat with just trackpump.
I think you are unlucky in your rim/tyre combos. Most nowadays go up with barely any effort with a track pump. Some need a burst from an airshot or compressor, but a lot don't .
Can you borrow an airshot or similar from someone nearby?
I'm gonna get a compressor from Amazon.
**** yeah I put sealant it!
Yeah they are advertised as tubeless ready, they are Kore Realm 2.7 and the tyres are WTB TCS. I used some Stan’s valves but they didn’t seem to seat too well in the flanges.
They might be tubeless ready rims. But might not have had tubeless tape fitted (unless I've missed something in skimming this thread)?
Make sure rims are clean and dry.
Tape the rims. If they tyres are a looser fit, a couple of wraps might be best. Tape them carefully, plenty of finger pressure in the channel and up on the shoulders. I used a hairdryer afterwards to soften the tape & make the adhesive more sticky, but that might be overkill.
I used a couple of inner tubes with the tyres on the wheels pumped up high overnight to straighten out the folds in the tyre beads and press down the rim tape.
Release the bead on one side, remove inner tube, insert valve (need a small, neat hole in the rim tape), lock nut done up nice & tight.
Fairy liquid on the rim hook / tyre bead. Splurge in some sealant. Pop the bead back onto the rim. Tyrelever trick to pull the bead onto the shoulder.
Remove valve core. Connect air shot. Let in air. Remove nozzle and quickly insert valve core (you will lose quite a bit of air. Pump back up. Rotate the wheel all ways / splosh the sealant around.
Job (hopefully) done.
It does need care. And doing properly. And a bit of luck.
(Hark at me, I've only done one set of wheels, and had other failed tubeless attempts before)
I can't get the tyre lever to pull the bead onto the shoulder. It just doesn't work.
Honestly I sick to death of this. I wasn't planning on riding my MTB for a week or two but my road bike I need. Now it's wheels off and waiting for a compressor (if that even works). I could put the tubes back in but every time I take wheel off I need to remove mudguard. Huge PITA for something I probably need to check the sealant of every 2 months anyway. Most useless bike technology I've seen since oval chain rings.
I love tubeless, it can be a faff but I usually manage without compressed air.
Try teasing the tyre out the of the well with your thumbs. I usually start with no sealant and no valve fitted and pump like ****.
If you can’t get a lever in to pull the bead how do you get an inner tube in and out ? Something isn’t right with tyre/rim combo by the sounds of it.
Have you not got any co2 canisters, they should get them seated
That takes the bead over the rim. Seating the bead isn't the same as having it within the rim.
It seems that the rim bed is too shallow for the tyres. Do you know how many layers of tubeless tape are on it ? Some tapes need one wrap, some thinner ones 2 or more. I think I’d be taking all the tape off and retaping the rim with a single wrap (plus 8 inch overlap at valve) of Stans tape or a couple of wraps of Tesa tape. Do you know what width of tape is on ? (and what is internal rim width) ?
Co2 worked great eventually! Lots of soapy water around the bead and with co2 it popped on first time.
While I don't really disagree with the first 2 points as genrall advice to anything I have never taken any care and always done it is a few minutes so I must have a lot of luck. I have probably setup around 5 sets of tubeless tyres and none have taken more than 10 minutes
Put on tape, press down a bit
Cut cross shape for valve with stanley knife
Do up valve with pliers to get it really tight
Put on tyre and pump up with track pump
Remove valve core, syringe in sealant
Pump up tyre with track pump
Ok one tyre on my MTB is now good. The sealant worked on the leak around the valve.
Will try other MTB tyre now,
I was trying the gravel bike again. I think by pushing the rim onto the shoulder with my thumbs I can make enough of a seal for the track pump to work well enough, thing is once I get a few psi into the system the air leaks around the valve flange like anything. 10 x worse than on the MTB like it may as well have no valve there. Can't get more than a few psi into the tyre cos of this.
I dunno what is wrong. Have a small gasket I home made. Valve is pretty tight. Is the rim tape all wrong? Seems like maybe air is getting under it?
That looks like ordinary rim tape to me not sticky stuff.
Tape looks suspect and certainly has a lot of sealant under. What tape is it? Doesn't look like stans/tesa.
Yeah I'll get some Stan's tape.
It's never going to work properly with a standard rim tape.
Yeah I'll get some rim tape tomorrow.
One thing I notice doing this is how shitty/bodged the valve fastens/interfaces with the tubeless rim. For at start you don't have perfectly flat surface on the inner and outer rim, yet you want to use a round wedge and a flat locking nut to make a seal.
This is a tubed design, made to easily accept a valve bonded to the inner tube with minimum fuss, now mechanically comprised in accepting tubeless.
Far better to weld/machine a threaded flange or nipple to the rim itself and screw on your valve of choice. You could either use PTFE tape or machine a small flat to create a seal with an o ring.
Sorry if this sounds a bit negative, but you have gone to town slating tubeless setup as a faff, but you aren’t actually using tubeless rim tape, despite a few of us asking about it earlier on. There are some really good YouTube clips from Stans and others that take you through the whole process, from start to finish. On your valve point, the tubeless valves all tend to be rubber based which sit well on tubeless rim tape. The seal is not on the outside, all the lock nut does is compress things inside the rim where it seals with its rubber base against the tubeless rim tape.
One thing I notice doing this is how shitty/bodged the valve fastens/interfaces with the tubeless rim. For at start you don’t have perfectly flat surface on the inner and outer rim, yet you want to use a round wedge and a flat locking nut to make a seal.
As Ian says, the seal is between the valve and the tubeless tape. If you'd done a tiny bit of research or spoken to someone in your local bikeshop or even asked on here rather than just plunging in thinking you knew it all you'd have found the process a lot less painful.
Just to add balance (not smugness, honest)
Just put together a new tubeless setup (for only the second time in my life).
Hope 20five 700c rims
Two layers of Stans tape
Simple cross cut, to poke Stans valve through
59ml sealant in each tyre
40mm nano rear
42mm resolute front
Popped tyres on, left the last bit open, poured in sealant, levered rest of tyre onto rim.
Used a bog std (little bit knackered) track pump and bingo! Straight up, bead seated at around 45psi, still holding pressure now, 3hrs later, no seapage
Seriously a piece of cake, although maybe I just got lucky, or maybe they will explode overnight, or maybe burp off the rim when I finally ride them...
