How hard is changin...
[Closed] How hard is changing a spring on RS Forks?
How big a job is changing the spring on Rockshox forks?
Been looking at Tora/Recon/Revs but standard sprind would probably be too light for a harderned pie-muncher like myself.
Wiksey
Posted : 03/02/2009 2:38 pm
Looking at doing the same myself and it appears to be straightforward.
Take the top cap off the leg, remove the spring and spacers, put the new spring and spacers in then replace the top cap???
Posted : 03/02/2009 2:58 pm
There's instructions somewhere on the sram site - sounds reasonably easy but I was still too scared. ๐Ÿ˜›
Posted : 03/02/2009 3:01 pm
Download manuals [url= http://www.sram.com/en/service/index.php ]here[/url]
Posted : 03/02/2009 3:27 pm
Cheers guys
Posted : 03/02/2009 3:29 pm
You need to half undo the bolt at the bottom of the leg, tap it with a hammer to release the spring, then remove the bolt as well
๐Ÿ™‚
Posted : 03/02/2009 3:30 pm
[url= http://www.tftunedshox.com/tech-area/rockshox-u-turn-spring-fitting.html ]Go looky here[/url]
Posted : 03/02/2009 4:15 pm
Its a doddle requiring the use of a mallet (or hammer & piece of wood), an allen key & a big socket. The big socket is because the top cap is alloy & a sloppy fitting spanner will chew it up easily.
Posted : 03/02/2009 4:19 pm
Just make sure you keep the fork horizontal after taking the uturn cap, bearings etc out otherwise you'll lose all the semibath oil out of the lowers! ๐Ÿ™‚
Posted : 03/02/2009 4:41 pm
I didn't have a big enough socket so used an adjustable spanner which was fine. A magnetic screwdriver or similar comes in handy for catching the u-turn adjuster bearings. It's an easy job really, even more so if you take the fork off your bike. And yes keep the thing horizontal! I got my spring from TFTuned and it came with a handy guide enclosed.
Posted : 03/02/2009 4:49 pm
I'm going to be doing this soon. What sort of weight/spring combinations are you guys at? I'm 12 st on a standard spring and find its too hard.
Posted : 04/02/2009 2:07 am
I'm about 13.5/14 stone and needed a firm spring.
Posted : 04/02/2009 2:39 am
I'm 13.5 and find the firm too soft (around 40% sag when standing) ...
I think that there is probably a bit of variance between any two springs of the same weight tho.
Posted : 04/02/2009 8:43 am
