The spec says:
[i]DT Swiss thru bolt - The DT Swiss thru bolt system is 100 % compatible with the quick release standard. Instead of a thin 5mm shaft, the DT Swiss thru bolt is an alloy bolt with a diameter of 9mm on the front hub[/i]
Will it work with a Hope Pro II front hub and a QR skewer? The 9mm through bolt has me confused. How is it [i]'fully compatible'[/i]?
It's from a DT Swiss XMC 100.
[img]
[/img]
it replaces the qr skewer with the axle. The axle slides into the cart bearings, has a lever at one end and a thread at the other, which you tighten.
So, it's not really suitable for swapping wheels between bikes then?
In other words, it won't work with a QR hub out of the box?
I think i have the QR version of this, Its the same as a stout hub,
http://www.chainreactioncycles.com/Models.aspx?ModelID=21670
This is what came on my dt swiss wheels, so won't go through a pro 2 unless you get something to adapt
You can swap the wheels between bikes with normal QR dropouts.
It's just like a Spec. Scraxle (sp?) thing. It'll fit any fork with QR dropouts, you'll just need to get the 9mm DT adapters for the Hope hub.
