How does one remove...
[Closed] How does one remove a rear maxle after handle has sheared off? Help!
It was my fault, it was stiff to screw in but I kept pushing, I wanted it nipped up tight - then the handle sheared off. I didn't push that hard though, honest! Thing is made of bloody cheese. Anyway...
How the shitting bollocks do I remove the axle now? Anyone get any great ideas? I've tried some needle nose pliers, but that's going to wreck the thread. Allen keys just spin.
Arsebiscuits!
Posted : 14/05/2019 9:31 pm
Cut a slot in it and use a screw driver.
Posted : 14/05/2019 9:42 pm
Make sure you turn it the right way though
Posted : 14/05/2019 9:44 pm
Hammer an old torxdriver into the threaded end and use that to drive it out backwards?
When that fails file flats on and see if you can back it out enough to get some pliers on The other end?
Posted : 14/05/2019 9:48 pm
I rounded out a stealth maxle so effectively had the same issue you did.
I jammed something into the other end and I un-screwed it that way - I can’t remember what I used though - might have been an easy-out.
Posted : 14/05/2019 9:52 pm
 RicB
Couple of nuts with the same thread/pitch. Tighten one against the other to lock them in place (leaving plenty of thread on the frame side obvs!), then just use a spanner to unscrew the maxle. Once is starts moving you should be able to do it by hand
Posted : 14/05/2019 9:54 pm
Bolt extractor from Screwfix into the hole should have it out in no time
https://www.screwfix.com/p/bolt-extractor-set-5-pieces/1112v
Posted : 14/05/2019 9:55 pm
Hammer in a spline bit/torx bit.
Try an extractor carefully (because they are tapered if its mega tight the extractor can split the part you are trying to remove).
Was the axle too long? (lot of exposed thread in the pic), the thread can bottom out before the axle clamps.
Posted : 15/05/2019 12:56 am
Thanks folks, appreciate the advice. Simon: harsh but fair!
I’ll try with a torx bit battered into the end first, and if that doesn’t work, then RicB bolts, then bolt extractor (noting caution).
Bigyan, yes, that was the issue - its a new fatbike frame, built for 197mm rear hub, which fits fine, but the maxle seems to be a few mm too long. I’ll get a washer for the next maxle- unless anyone knows of an alternative?
Posted : 15/05/2019 7:44 am
Good news, the torx trick worked a treat. Yah beauty! Many thanks folks, I was a wee bit depressed last night.
Even better news, turns out an old surly bolt through axle fits perfectly, and he’s the benefit of no cheese based components. Woohoo!
Posted : 15/05/2019 10:32 am
