How do you progress...
[Closed] How do you progress from rolling some steps to jumping down them?
There's this nice little set of 5 or 6 steps in a park by me midway through a bit of twisty singletrack. I have visions of ragging down and just jumping straight down but always find myself slowing to roll them.
How do you make the transition to jumping them as I cant see how you can build up to it?
Is it a case of just thinking fekk it and hitting it at a higher speed? Don't really want to break myself and still be there covered in dew the next morning! ๐Ÿ˜ฏ
Posted : 03/05/2013 3:33 pm
depends what you want to acheive? a huck off them to flat is going to be nasty, fastest would probably to slightly pre-jump and pump down them.
Posted : 03/05/2013 3:35 pm
Hmm yeah that's kind of what I am imagining ๐Ÿ™‚ It is a landing onto grass but yeah it goes to flat.
Posted : 03/05/2013 3:36 pm
 m0rk
whichever you do, can you set a camera up to capture the [s]blood[/s] smooth landing
Posted : 03/05/2013 3:39 pm
๐Ÿ˜€ this is why I will never progress. Too old to go risking things ๐Ÿ™
I'll just continue to bimble down them and imagine myself being graceful.
Posted : 03/05/2013 3:42 pm
Drink a lot.
Posted : 03/05/2013 3:44 pm
how's your manualling?
If you can shift your weight back over the back wheel as you go off a kerb so your back wheel lands first, do the same on a smaller set of steps, then these ones, you can let the back wheel run down the steps and absorb the impact on the back wheel as you land.
Then faster => missing out a few of the steps on the way down. Clipping the bottom one or two with the back wheel isn't the end of the world, if you're ready to land on the flat on the back wheel, they won't slow you down.
It's probably a 2.5 foot drop to flat? Look at it like that?
Go faster.
Pray. ๐Ÿ˜€
Posted : 03/05/2013 3:45 pm
Yeah the manualling would sort it. Can't manual though apart from the odd rogue one ๐Ÿ˜€ Maybe I will work on that first.. either that or go the 4 pack of stella /go pro camera route.
Posted : 03/05/2013 3:52 pm
Try something like this
Posted : 03/05/2013 3:58 pm
You might consider it 'typical expensive stw response', but a skills course would no doubt see you right for this; plus improve your overall riding ability
Posted : 03/05/2013 3:59 pm
50m long manuals aren't necessary. Cool as ****, obviously, but not being able to do them won't stop you here.
If you can keep your weight far enough over the back wheel that the front stays up for 1 or 2 seconds, that's probably enough. Once the back wheel reaches the stairs, your weight will push it down the steps, the front will stay up, back lands first, ride into the sunset.
If you can land back wheel first off a kerb by manualling at a slow jogging speed, I reckon that's as much manualling steez as you need.
Posted : 03/05/2013 4:08 pm
footflaps has got the right idea.. once you have learnt the basics from that vid, try this more advanced technique
Posted : 03/05/2013 4:10 pm
Important lesson from the vids; call 999, then when the paramedics arrive explain what you're about to do.
Posted : 03/05/2013 4:19 pm
Use the force......to seek out Jedi (UK Bike Skills) who'll help you do it safely ๐Ÿ™‚
Posted : 03/05/2013 4:24 pm
I have similar thoughts about bigger jumps and drops. I am happy doing smaller jumps and drops but ask myself how do I progress to bigger stuff? The answer unfortunately is always grow a bigger pair. I know I can do it, and have the ability to do it, but my swingers just ain't big enough! I bet deep down you know you can jump those steps, it's just a case of getting over your inhibitions and having the confidence to commit yourself. Wish I knew how! I need psychological training I reckon
Posted : 03/05/2013 4:29 pm
Thing about steps is, they're amazingly easy, they just sometimes don't seem it, and they come in convenient sized packs. 6 is a slightly awkward number- if you want to jump onto the steps, it's quite short, but if you want to drop them entirely, it's reasonably tall.
So practice dropping on a smaller set, and practice jumping into them on a bigger set, if you can. Do some skidz while you're at it, and sidehop badly off a kerb or two.
Posted : 03/05/2013 4:30 pm
My personal technique is pull up, pump down.
Covers all sorts really but once you're in it, 10 or a 100, much of a muchness.
Eg:[IMG] [/IMG]
Y'ken [b]Northwind[/b]?
Edit: Not much clearing to be had there mind.
Posted : 03/05/2013 4:56 pm
I wouldn't manual, just treat it like a drop off and you'll hardly feel it.
Posted : 03/05/2013 5:05 pm
Drop 'em to flat cf
Posted : 03/05/2013 5:35 pm
Actually, that's a fair point.... Semi-Hijack.
Stair Set Thread>Edinburgh's the place...check it part 2
NEXT!
Posted : 03/05/2013 5:56 pm
Broke a frame on them as a student whilst slightly drunk. Didn't notice till mate told me my back wheel had slipped and I was going sideways.
Posted : 03/05/2013 8:19 pm
I'd find a smaller set of steps somewhere to practice your technique on and gradually work your way up to that set. If you can land perfectly off a tall kerb then you can land perfectly off a big drop but you need to be able to land front first, rear first and both together and do whichever suits the situation. Jedi is awesome and Mastering Mountain Bike Skills 2 is an excellent reference guide in the meantime.
"Don't do the height until you're dropping right!"
Posted : 03/05/2013 8:42 pm
For just 5 or 6 steps I would just go faster and use suicide grips. All these big sets of steps have nothing to do with your stairs. Just hit them and make sure that you absorb the landing with your arms and legs.
Posted : 03/05/2013 10:22 pm
Just think if you go just a little bit faster you'll be going down them without actually touching them.
Posted : 03/05/2013 10:32 pm
Visualise success then stop thinking about it and just do it.
Post the video after you're done.
(Said by a 42 yr old who has no desire to wreck his body anymore)
Posted : 03/05/2013 10:48 pm
5-6 steps? Jump to flat.
As long as you can drop of something the same height, you'll be good to go.
Posted : 03/05/2013 11:31 pm
i often get baffled by people who look in terror at a 3-4 ft drop, without a bike they would hop off it without a thought but won't do it with 4+ inches of extra suspension and the ability to use their arms as well as legs to soak up the rather light impact of landing.
Posted : 03/05/2013 11:44 pm
Would that be people who spent their childhood jumping off things on their two feet and thus instilling the correct techniques and mindset to cover them for the rest of their life (until they're properly old) but didn't do the same on two wheels and are having to learn jumping techniques as an adult?
Posted : 03/05/2013 11:49 pm
I don't know.. I think twice sometimes about jumping off the bottom couple of stairs at home in the house these days.. ๐Ÿ™
I think I'm going to use B45her's mental approach a bit more often on the bike though, great idea
Posted : 03/05/2013 11:53 pm
there is no "technique" to smallish drops its just a case of riding off them. 90% of jumping/dropoff's is having the plumbs to commit to them, there's very little skill involved.
Posted : 03/05/2013 11:56 pm
Nonsense. It's all about technique breeding confidence & commitment and nothing whatsoever to do with the size of your balls.
Balls-technique=pain.
Get some coaching.
Posted : 04/05/2013 12:10 am
no thanks i don't need to give someone money to coach me how to jump a bike i've been jumping bikes just fine since the age of 10.
Posted : 04/05/2013 12:21 am
Which means you probably don't realise how much technique is involved because you started young and it's instinctive for you now. In an ideal situation you can just ride off a drop and as long as you're relaxed you'll land it fine. But where I ride ideal situations are rare - drops have angled take-offs and landings which require you change the attitude of the bike in mid-air, drops happen just after and just before corners so the entry and/or exit aren't simple and drops happen in places where you're going too slowly to just stay relaxed and centrered or too fast to enter without slowing first (or you'll end up going seriously large and landing to flat with a crunch).
Posted : 04/05/2013 12:32 am
I used to have a lot of anxiety about gapping double sets of stairs, until one night I got particularly sloshed and went out and did a set first time. Ever since then it never bothered me... I'm not suggesting that's how you do it, just saying that over-thinking is usually the problem ๐Ÿ™„
Posted : 04/05/2013 1:53 am
