how do i stop shape...
[Closed] how do i stop shaped rotors from pulsing?
Slx brakes and clarks Rotors. Front pulses so bad the forks vibrate! Any way to stop this?
Posted : 08/11/2010 11:03 pm
Some calipers/pads just don't work with certain rotors.
Are you running the same brakes/Rotors front and rear?
Posted : 08/11/2010 11:05 pm
Yes with the same problems
Posted : 08/11/2010 11:12 pm
http://www.chainreactioncycles.com/Models.aspx?ModelID=47541
Posted : 08/11/2010 11:15 pm
Ive currently got some xt's doing the same with superstar flames, think they are going in the bin ๐Ÿ˜•
Posted : 08/11/2010 11:19 pm
Used to get a similar problem on Mono Minis, most noticable on tarmac. Reckon it was due to the braking surface tapering between the rotor's spokes, a set of Shimano rotors with concentric braking surfaces cured it.
Posted : 08/11/2010 11:23 pm
Put them in a lathe. Carefully turn down the outer surface until they're perfectly round like a proper rotor. Fit them back on your bike. Take them off again and throw them in the bin when you realise they now work even worse, and buy the normal rotors you know you should have got in the first place.
Posted : 08/11/2010 11:29 pm
