So the valve on my rear wheel snapped off, leaving me the ability only to let air out unless I use some pin to push down when attaching pump,
Looked into it and it appears I can replace the core???
Can this be done without taking the tyre off?
Posted : 13/09/2013 7:28 pm
Yes, if its a replaceable valve core it's like the pic below, just unscrew it with some needle nosed pliers and screw the new one in..
[IMG]
[/IMG]
Or use the little black tool in the pic, the hole goes over the end of the valve and you squeeze the end together and unscrew it.
Posted : 13/09/2013 7:31 pm
