How do I get my bea...
[Closed] How do I get my bearings in straight?
[#8246965]
Main pivot bearings - they pressed out ok with a bit of threaded rod and appropriate sockets but the little toenips don't want to go back in. They keep favouring one side or the other. Anyone got any tips?
I just walked away before I make a big mess.
Posted : 28/12/2016 7:26 pm
I push mine in slowly with the appropriate sized socket and a large g-clamp.
[url= https://www.amazon.co.uk/Draper-51954-150mm-G-Clamp/dp/B0002BUUNO ]Draper G Clamp[/url]
Posted : 28/12/2016 7:42 pm
It can help to freeze them overnight too.
Posted : 28/12/2016 7:50 pm
If you have a hot air gun , give whatever the bearing is going into a good heat (even better with alloy). That & a frozen bearing usually drops in.
Posted : 28/12/2016 7:54 pm
Thanks, guys. Bearings in the freezer and rear triangle by the radiator (instead of in the freezing cellar) overnight. I'll let you know how it goes tomorrow.
Posted : 28/12/2016 8:01 pm
Both really good tips. Use a hair dryer if you don't own a heat gun.
If you are going to service your own FS bikes I can honestly say that a bearing press is one of the best buys you can make.
There are good bike specific ones out there for not a great deal of money.
Posted : 28/12/2016 8:11 pm
Use the old ones as an enlarged washer
Posted : 28/12/2016 8:12 pm
Or stick the frame part in pan of boiling water for 10 minutes to 'expand' it
Posted : 28/12/2016 8:13 pm
[quote=mikedabear ]
such as?
such as?
http://www.ebay.co.uk/itm/Bike-bearing-press-for-pivot-and-bb30-bearings-/322361124402?hash=item4b0e386632:g:d3wAAOSwnOJWFQm0
for instance.
I would even suggest investing in a bearing puller and then you can service or change any bearing on any bike you own for the rest of your riding days. 🙂
Posted : 28/12/2016 8:58 pm
Are you trying to get them in one at a time or both together?
Posted : 28/12/2016 9:02 pm
What makes that bike specific other than the word bike in the eBay title ?
It's just a bolt and some thick washers.
I have similar spacers I use with my floor standing press.
They didn't cost 25 quid and go from 10mm to 42mm just ALU disks
281751939405 is eBay number for what I have as eBay app is crap.
Posted : 28/12/2016 9:28 pm
One at a time using the old bearing as a "press". Definitely a job where the correct tools make a difference. Those ebay ones look good for the money. I'll find a decent puller for next time too - any recommendations? The Superstar ones in my size are sold out.
The bushings match the sizes you will find in bike construction.
And not every one has a floor standing press handy.
The "thick washers" are made of plastic and are matched exactly to the bearing size.
I personally have something more extensive and expensive but some thing like this is ideal for the home bike mechanic.
Posted : 28/12/2016 9:41 pm
Slowly with a drift working round works for me
Posted : 28/12/2016 11:40 pm
Bearings should be pressed, but never ever hammered, or even tapped in.
Posted : 28/12/2016 11:42 pm
I have been known to take mine to a bike shop give someone £30 and they come back straight and true
Posted : 28/12/2016 11:44 pm
All done - pressed not hammered. They didn't just drop in though.
New tools for next time without a doubt.
I can highly recommend TFT's press for shock hardware - works a treat.
Posted : 29/12/2016 4:56 pm
Why?
Posted : 29/12/2016 7:24 pm
 JAG
Why?
Because the impact of a hammer can cause damage to the bearing race surface and you'll end up with a rough bearing before the bike event turns a wheel.
Does kinda depend how you hit it though 😆
Hhmm just realised I'm assuming ball-bearings and I guess you may have plain bearings 😉
Posted : 29/12/2016 10:40 pm
If you tap it in by the outer race it should be ok then?
Posted : 29/12/2016 11:07 pm
... assuming you only load the outer edge of the race and don't slip ...
Applying equal force with a press is much safer for the bearing. The proper tools can be had for cheap enough that you may not save money over paying a shop the first time you use them, but by the second use you're definitely in front and with a better life expectancy for your bearings 🙂
Posted : 30/12/2016 1:49 am
