How big are Canfiel...
[Closed] How big are Canfield Crampon pedals
If you've got some of these, how does the platform area compare to other pedals? If you could give me a measurement side-side or front-back that would be great.
Also I notice they are symmetrical front to back, unlike most pedals which are symmetrical around the spindle. Do you find this makes you put your foot further back?
Posted : 14/01/2010 1:52 pm
Never mind, I worked it out meself.
Assuming STW use standard post-it notes it looks like about 106mm wide, 108mm front to back.
I reckon it's accurate to around 1mm, so if someone ever sees this and measures theirs let me know!
Posted : 19/01/2010 8:09 pm
 jedi
and that took you 5 ****in days??? ๐Ÿ™‚
Posted : 19/01/2010 8:11 pm
lol
I'm a slow worker
Posted : 19/01/2010 8:13 pm
More importantly, anyone know if they are any good??
Posted : 19/01/2010 8:40 pm
Just received mine this morning. 108mm front to back, 104mm wide. Good post it note measuring matey.
Posted : 19/01/2010 9:07 pm
Thank you sir!
Let us know how you get on with them.
Posted : 19/01/2010 9:20 pm
Anyone know who sells them in the Uk?
Posted : 19/01/2010 9:43 pm
have a chat with 18 bikes
Posted : 19/01/2010 11:03 pm
I've just got some of these... prepare to get blisters fitting the 40 pins yourself...
Posted : 27/01/2010 11:24 pm
have you ridden them yet si?
Posted : 28/01/2010 12:17 am
no, tomorrow night I hope. They feel good. Strange thing is though, once the pins are in the pedal is quote thick. The pins are 18mm long.. making the pedal about the same thickness as other low profile pedals out there....This negates the claim that you get your foot lower down due to the profile.
Posted : 28/01/2010 12:27 am
I'd have thought something like a fiveten sole would sit flat to the pedal having "absorbed" the pins ?
Posted : 28/01/2010 12:32 am
There is a review on southerndownhill....
Posted : 28/01/2010 9:42 am
Found it
http://www.southerndownhill.com/forum/index.php/topic,215222.0.html
Posted : 28/01/2010 10:03 am
If mine ever turn up (ordered dec 22), then I'll let you know
Posted : 28/01/2010 10:06 am
Standing on them with a 5ten last night, the pins only sink in 1 or 2mm, I suppose the other 17mm platform pedals out there are a little thicker as the pins on them stick out 4/5mm.
Posted : 28/01/2010 12:49 pm
Do they feel a bit wider than other pedals? They look it.
Posted : 28/01/2010 1:00 pm
Mine turned up Saturday, along with my freebie Canfield Bros Tee (thanks chris, if you're reading this). Compared to my V12's, they're huge platforms, I'll take a comparison pic.......
Posted : 02/02/2010 6:08 pm
Ok, this may work, or not.
V12 91mm at the widest point, Crampons 107mm wide.
Posted : 02/02/2010 6:28 pm
