Hope x2 brakes
[Closed] Hope x2 brakes
 RegP
Hi all
Just got my new brakes as above to replace my old xc4's, I am running xt shifteres, found that the down shift leaver is difficult to access as part of the brake body is in the way, is there any way to get around this, or do I need new shifters, recon the shifters are about 4-5 years old.
Pics appreciated if you have any idea's
Thanks
Posted : 04/07/2009 8:13 pm
The tech levers are longer than old hope levers. The brake levers need to go inside the shifters (ie the shifters are nearer the grips. You have to remove the optics on the shiters to achieve this fit. Hope confirm this with pictures on their website.
Posted : 04/07/2009 8:19 pm
 RegP
Any idea under which bit on the website?
Thanks
Posted : 04/07/2009 8:30 pm
[url= http://www.hopegb.com/page_mep_force_60.html ]
If the link doesn't work it's on the home page about half way down the "latest news" section.
Posted : 04/07/2009 8:35 pm
 RegP
Thanks found it how easy it it to remove the optical display? Is this a simple job?
Posted : 04/07/2009 8:44 pm
[url] http://www.hopegb.com/page_mep_force_60.html [/url]
Posted : 04/07/2009 8:47 pm
Yeah my x2's suck, when I have the levers in the right position the shifter contols are wrong and vice versa
Bring back Shimano Dual control...............
Posted : 04/07/2009 8:49 pm
there should be 2 small screws that fix the optical display to the main shifter plate...it then just lifts off.
Posted : 04/07/2009 8:50 pm
