Just bought some blue levers (Bling) is it easy just to swap levers over, or is it strip down and re-bleed???
Posted : 14/08/2012 7:01 pm
Easy to do no bleed req but a bolt and small grub screw to remove to release the lever.
Do the new levers have the adjuster screws ?
If so only above to do
If not you have to remove a small circlip at the back of each of the existing screws to release them from the lever.
Hope that helps
Posted : 14/08/2012 7:20 pm
Cheers shredder
HOPE that works !
Posted : 14/08/2012 7:47 pm
