Just currently attempting to spec an upgrade for my Vision 2 light.
Through the wonders of Google I have found the following XM-L Led's I may need:-
http://dx.com/p/xmlawt-1000-lumen-led-emitter-white-light-bulb-3-0-3-5v-51989
http://dx.com/p/xm-lt60-1000lm-led-white-light-emitter-with-18mm-base-2-9-3-5v-54704
Which of the following would be the best/most preffered one to use?
And through previous threads a driver board from here..
Yet to spec a switch yet, most likley a push button (will look into this later on)
Also thermal paste for the fixing of the LED's.
Is there anything else I may need?
Phil
The led-tech one for sure. You could use a much cheaper driver than a taskled one but they are good, I use a few myself. An LFlex might do you, drop them a line telling them your plans and which battery you have.
Thanks PM, will pop them am email.
