Hope V-Twin - power...
[Closed] Hope V-Twin - powerful?
 Rik
[#6824358]
Are they supposed to be more powerful than Avid BB7s?
Just installed a set, after running BB7s for years and I was expecting at least as powerful. I could lock up the bb7s at any point if I wanted. Seems that the Hopes need more of a pull to get the power, fine from the drops but not from the hoods.
Just changed the pads to see if it was that.
Posted : 31/01/2015 11:25 am
Not really an answer to your question, but I wonder if Hope are going to get pushed out of the disk brake market given that road bikes combine brake lever and gear shifter? V Twin isn't going to tempt anyone over the full shimano or SRAM hydro setup.
I can't see how they can benefit from the growth in road bike disk brakes, without teaming up with a group set manufacturer (of which there are few/none without disk brake solutions already). Unless I'm being thick and you can run a hope calliper with a shimano lever.
Posted : 31/01/2015 11:49 am
[quote=bainbrge ]Not really an answer to your question, but I wonder if Hope are going to get pushed out of the disk brake market given that road bikes combine brake lever and gear shifter? V Twin isn't going to tempt anyone over the full shimano or SRAM hydro setup.
TBF, it was hardly a major market for them anyway so not much to lose.
Posted : 31/01/2015 11:50 am
 JoB
the Hopes are powerful, but as you've experienced modulation from the hoods can be poor, where it can be very hard to pull the lever, a smooth cable run from the lever to the unit helps here
Posted : 31/01/2015 11:55 am
I guess, but the MTV market probably(?) isn't growing, and there's lots of competition. The road disk market is growing like the clappers.
Just seems a shame to be locked out of the road market due to the existence of dual brake/gear shifters.
Posted : 31/01/2015 11:56 am
 Rik
I've got a smooth cable pull as in using v brake noodles to the unit itself.
Modulation is not that odd. It's just to get any power from the brakes I have to pull a lot harder than I did from the bb7s. As they are part hydraulic I thought id get more power for less effort. The cable part is using compressionless cables.
Thats why I thought it might be the pads or needed a bleed etc. but as I have not tried another persons v twins I don't know what 'good' should be.
Posted : 31/01/2015 12:08 pm
Got a V Twin setup on my CX, it was the only option for mechanical 10sp shifters + hydraulic brakes at the time I built it.
It can be very powerful but it's susceptible to poor cable routing. Run it with the best quality cables you can, ideally those Shimano super-slippy ones and change them regularly. Keep a nice smooth curve from the bar down to the under-stem converter. They're very very good but they can take a bit of time to get them just right. Also, they bed in. First long road descent I went down, the difference between top and bottom was incredible. They need to be run hot to work best.
Posted : 31/01/2015 12:13 pm
I looked at a pair of v twins but in the end went for hyrds - excellent from the hoods or the drops though a bit of a faf to set up.
