Hope Tech 5
Hope Tech 5
I've heard rumours on another forum of a Tech 5 lever with a bleed port screw on the lever rather than taking the reservoir cap off
Has anyone seen, or know anything if them?
I was quite surprised to hear it as Hope normally have quite long product cycles but the Tech 4 still feels quite new
Posted : 16/05/2025 8:08 pm
Didn't they/don't they make a bleed cap you can put on in place of the normal cap when bleeding?
Posted : 16/05/2025 8:35 pm
Posted by: nixie
Yes they did.
I really doubt there’d be leaks about new products from a company that designs, manufactures and markets their products in house in the UK but you never know
Posted : 16/05/2025 8:44 pm
They could easily make a new reservoir cap with bleed port that fits in place of the existing reservoir cap.
Then it would be backward compatible.
Posted : 16/05/2025 9:10 pm
b33k34 reacted
They do but you have to remove that bleed cap and fit the diaphragm and plain cap at the end of the bleed.  This can be a little messy and has to be done carefully to avoid leaving air in the resevoir.
It's not quite that easy as the diaphragm has to be incorporated in the design.
Posted : 16/05/2025 9:20 pm
I knew I'd seen it somewhere... 20250514_UCI_EDRDH_WC_BielskoBiala_SR30858.jpg
Posted : 19/05/2025 6:23 pm
Yeah, saw this on MTBR. Looks like it's an evolution rather than a revolution. Normally a new version of a hope lever is a very visible change, this seems much more subtle. Just a tweak to the existing design.
Posted : 19/05/2025 6:26 pm
Lever blade looks a lot nicer.
Posted : 20/05/2025 9:41 pm
I can't see many differences other than cosmetic.
Posted : 21/05/2025 6:23 am
Posted by: nixie
There's what looks like a bleeding port behind the master cylinder. Hopefully removing the need to always remove the top cap and diaphragm to bleed it.
Posted : 21/05/2025 6:53 am
The levers do look nicer, I preferred the tech 3 aesthetic.
That torx does look like it could have the potential to be a bleed point.
Posted : 21/05/2025 6:57 am
I hope that bleed port really is coming…
Posted : 21/05/2025 7:15 am
 P20
Pinkbike
https://www.pinkbike.com/news/spotted-hopes-new-gb4-brakes.html
Posted : 31/05/2025 10:23 am
 igm
The one brake that probably didn’t need to make bleeding any easier…
But I’ll take it.
A similar bleed port on the caliper so you could do a reverse bleed in less than 5 minutes would be a bonus.
Posted : 31/05/2025 10:59 am
The Hope aren't difficult to bleed but if we're talking about easy bleed brakes, nothing touches the Intend Trinity.😉
Posted : 31/05/2025 11:55 am
 igm
@onzadog
I had a look at their video, there’s some nice touches with that Intend brake - particularly the hose fitting (assuming it works long term of course).
The bleed itself looked remarkably similar to the bleed I did on a Shimano levered Hope RX4+ the other week (Hope supplied bleed blocks and all).
Except the Shimano Hope one, the funnel screws in as does the syringe into the caliper.
It wasn’t fast as getting everything aligned so the bleed ports are at the high point takes a little time - but it was painless.
If Hope put the a similar screw in caliper port in the X2, E4 etc callipers and the port on those Tech levers is also a screw in I reckon that’s better.
Even better if we could have a mineral sized bleed port screw and a DoT sized one, folk wouldn’t get their bleed equipment all mixed up.
Ok sorry, standard standards. Never going to happen. I took it too far.
PS - I did like the way the Intend bleed port had a valve too.  They’ve clearly had a good think and there wasn’t much to improve - assuming it works in Yorkshire / PdS
Posted : 31/05/2025 2:04 pm
Very easy to bleed Hope brakes, but it's still a messier job than doing brakes with a bleed port so this is long overdue, but not worth upgrading for.
(they really should have done this when they upgraded the lever last time)
Posted : 31/05/2025 2:08 pm
Clear pictures here....
Posted : 31/05/2025 3:55 pm
Am I the only one who thins that bleed ports are a backward step (cost cutting?) on callipers?  Changing to a grub screw plugged port on the brake calliper just seems to introduce an opportunity for air to get into the system in a location where it's going to be difficult to shift.  I'd rather have a proper nipple, thank you.
Posted : 31/05/2025 3:58 pm
I feel like sram have got the idea design with the bleeding edge port - so clean at the caliper end with no leakage
Posted : 31/05/2025 4:04 pm
b33k34 reacted
Absolutely. I’ve changed the screws in my TRP calipers to bleed nipples for that reason. The location also made it impossible to do a quick (emergency /lazy) wheel on bleed
Posted : 31/05/2025 4:35 pm
But doesn't the Marshy method of bleeding Shimano brakes include removing the caliper bleed nipple because that's where air can get trapped, this suggests nipples aren't better... TRP bleeding worked fine for me without the nipple as the syringe with correct adapter could screw straight in which I preferred to a hose on a nipple
Posted : 31/05/2025 5:17 pm
They look pretty in red.
Posted : 31/05/2025 5:40 pm
So I guess this is the Hope Tech 4 Evo lever (new lever shape and bleed port added), and GR4 caliper. Can’t see why you can’t bleed it the usual Hope way too. I wonder if the GR4 is replacing the V4 or if it’s a non-vented clearance downhill caliper?
Posted : 31/05/2025 9:02 pm
kelvin reacted
Bleed nipples are used in millions of car and bike systems. More likely that it’s MTB engineering that’s the limiting factor e.g. incredibly small system volume
My TRPs love to start spilling out oil as soon as the grub screw or syringe are removed.
Posted : 31/05/2025 9:26 pm
Adam Brayton was running them in his latest video and they say EVO on the top caps.
Posted : 09/06/2025 10:07 pm
It's more than a bleed port...
Posted : 25/06/2025 8:36 am
Everything you need to know:
Posted : 25/06/2025 9:15 am
 nbt
Posted by: chiefgrooveguru
GR4 is not compatible with vented rotors according to the promo
https://www.hopetechhb.com/evo
Posted : 25/06/2025 9:30 am
TR4 - and the others were GR4 - so trail and gravity?
Sign me up for a set of trails
Posted : 25/06/2025 9:36 am
That's my Christmas present to myself sorted then. The current brakes are great and I'm so glad they've finally addressed the sloppy bleed procedure.
I'll be happy to move my E4's to the trail bike and go for maximum power on the the bikepark/uplift bike.
Interesting. Is the "power" lever the same at the tech4 (for comparison).
Posted : 25/06/2025 9:42 am
GR4 is not compatible with vented rotors according to the promo”
A good prediction! Hardly anyone uses the vented rotors and the extra clearance means the pistons have to come out further for standard discs.
Looks like a nice load of improvements all round!
(Does anyone else read the name on the lever as Evona?)
Posted : 25/06/2025 10:05 am
Wonder if this means less fluid in the system for GR4 over V4 using the same discs?
Posted : 25/06/2025 10:07 am
Posted by: kelvin
The blurb talks about the whole form factor being smaller, thinner bore caps, fits into frames more easily, so you're probably right
Posted : 25/06/2025 10:29 am
Bugger, bought a set of the old ones a few months ago! Never mind, they're ace.
Posted : 25/06/2025 11:43 am
Posted by: kelvin
There are 3 levers, and to me it looks like there is a 'standard' lever - which would presumably be the equivalent of the current lever blade.
You then have the option of 2 alternatives, which use different geometry - one is the 'power' blade, think Shimano, instant, sharp power but less feel, the other 'control'  is more like the older Tech 3 Hopes - much softer feel, more modulation, without the grab.
You can see this very clearly on the video at 78s (direct link)
and the differences in geometry from where the lever pivots, to where the lever pushes on the master cylinder.
Posted : 25/06/2025 11:52 am
Me too, bought V4s, they're great. Seems these not available to order until August anyway
Posted : 25/06/2025 11:54 am
Stockists will be delighted at all the extra combinations
Posted : 25/06/2025 11:59 am
Posted by: mashr
I'm not 100% sure that's Hope's business model - people will keep some stuff in but much of it will be CNC to order.
I take it the new lever blades aren't backwards compatible?
Posted : 25/06/2025 12:10 pm
 P20
I like the idea of the bleed port, but different size pads to my current tech 4s. I’ve been looking at a set for the FS, I’d rather stick with the Tech4 and have an easier life of two bikes with the same pads. First world problems!
Posted : 25/06/2025 12:15 pm
Are these all new pad sizes? Or is it just the TR4 stepping up to same size as GR4/V4? Confused.
Posted : 25/06/2025 12:30 pm
Posted by: mashr
Not sure they'll be bothered as my LBS says Hope are very good at getting stock to shops very quickly.
Posted : 25/06/2025 12:45 pm
kelvin reacted
Thinking of the bigger shops e.g. Biketart of Merlin. Currently they just have to hold the various colour options, now they could be looking at triple the number of SKUs
Posted : 25/06/2025 1:03 pm
Every time I've ordered Hope stuff recently it hasn't been in stock. I've configured it on a web page and the dealer has ordered it then shipped it out. It takes a bit longer makes more sense for shops than holding every option.
Posted : 25/06/2025 1:15 pm
It's an all new range, so GR4 replaces V4, TR4 replaces E4
All brakes will ship with the standard lever, if you want Power or Control levers they're an add on.
Lower profile caliper is part of the story, yup.
Order book at Hope opens in August, but we're taking orders for a £50 deposit to get folks as close to the front of the queue as possible -details here!
Posted : 25/06/2025 3:41 pm
I'll have a set of GR4 but I can happily until they're slightly reduced somewhere. Not bothered about beating any queues.
Posted : 25/06/2025 6:45 pm
The GR4 looks ideal to me. But I'd need a set in early August, and probably spent too much recently anyway. Got to do something about my Codes before going to the Alps. They just don't slow me down sometimes. It's either new brakes or 220 rotors front and rear.
Posted : 25/06/2025 9:39 pm
@bitmuddytoday have they been bled and set up recently?  That, plus fresh pads can be a big help on DOT fluid brakes in particular.
Posted : 26/06/2025 6:10 pm
My thinking is,
I'm going to build my 7year olds next bike soon. (It's currently stored in bits in the garage). If I got some Evo X2 s I could put the levers on my e4s and my tech3 levers on the x2 s on my lads bike.... After all, it's not for me it's for him.
Posted : 26/06/2025 6:54 pm
I don’t think the levers are interchangeable/retrofit to older models.
Posted : 26/06/2025 10:13 pm
Posted by: rockhopper70
That's what hope say - though I assume they mean "lever blades" as opposed to the whole lever assembly -
Posted : 27/06/2025 12:53 pm
kelvin reacted
I assume the whole leaver assembly can be moved across.
The lever blades and cams were not cross compatible between tech3 and tech 4 without some modifications.
Looks like all the same fittings
Posted : 27/06/2025 1:25 pm
I'd think the blades would be compatible with the Tech4, but the cams look different when you see the underside. There's a track in the MC body for an actual cam, and a pin that fits into the back of the piston rather than a roller
Posted : 27/06/2025 1:51 pm
I don't understand why you would want to retrofit the new levers to old callipers. In my experience it's a false economy as the increased sale price of the full brake set comfortably offsets the purchase price of the new set, normally resulting in a smaller final outlay than buying the levers separately.
Posted : 27/06/2025 2:38 pm
Has anyone been running the new Evo TR4 yet?
My old Shimano XT 4pots are still good (wandering bite point aside as a minor annoyance), but wondering whether to move to these. Never used Hope brakes before, so keen to hear how these shape up.
Posted : 27/11/2025 12:16 pm
Not used the new tech4 evo.
I used some tech3e4 for years and they have been faultless.
I have some tech4e4 and they're stick in the spokes compared to the tech3.
I'd love to upgrade to the evo but I don't ride enough just now.
As it is I'm building up a 24" bike for eldest and I've got some second hand tech3x2 to put on as I've found them more reliable than the 3 sets of shimanos I have in a drawer
Posted : 27/11/2025 12:30 pm
Posted by: orena45
I have the TR4s. They are just fantastic brakes. I like the Tech 3 E4s on the hardtail, was very impressed with the Tech 4 V4s on the ebike, and now have TR4s on the trail bike and they have nearly all the power of the old Tech 4 V4 but a much, much nicer lever feel and shape.
Posted : 27/11/2025 1:46 pm
I'm interested to hear from anyone who has tried the TR4 and GR4.
Any difference in power delivery or lever feel? I prefer a short throw and a faster bite. I'm sure they both have more than enough stopping power.
Posted : 27/11/2025 1:52 pm
I'll be investing in the GR4s at some point for sure, the TR4s are that nice. I just need a few more weeks of self justification before ordering them
Posted : 27/11/2025 2:20 pm
