Hope SS/Trials to g...
[Closed] Hope SS/Trials to gears 1x6 (help, I know nothing)
Hello,
I have a hope SS/trials hub on the 29er but I want to try 1X6. Where do I bloody start?
I am really clueless on this subject.
Can I just buy a Zee short rear mech, Zee shifter and find a 10spd cassette that I can take apart?
or will 9spd be easier to use?
Do you have a tried and tested arrangement?
Posted : 27/08/2014 8:43 pm
Hi, I'm using the same hub with the smallest 7 cogs of an XT cassette (so 7 speed). The biggest 3 come on a separate spider so you just don't fit that and fit the rest as you would a normal cassette. I'm using a Zee mech and a 10 spd XT shifter and chain. With a 30 tooth Raceface narrow/wide ring it all works a treat!
Posted : 27/08/2014 8:49 pm
There's a good thread on mtbr about various set ups. I have 7 9sp cogs (XT) with XT shifter and Saint rear der. I've done this on 2 frames, the only tweak I had to do was put a thin washer on the rear der mounting bolt on one of the frames to get the pully/cassette clearance.
People have managed to fit 8 10sp cogs.
Have a read through this lot:
[url= http://forums.mtbr.com/29er-components/6-cogs-ss-hub-best-solution-458083.html ]http://forums.mtbr.com/29er-components/6-cogs-ss-hub-best-solution-458083.html[/url]
Posted : 27/08/2014 9:44 pm
