hope pro4 rear hub ...
hope pro4 rear hub issues
hi all i'm having play in my rear pro4 have replaced all bearing and still it persists has anyone encountered a cure such as thin shims or replacement parts ?????
cheers mark
Posted : 08/08/2024 11:33 am
You must repair it! Sir, if any of my shims or gears will help, I'll gladly donate them.
Posted : 08/08/2024 12:01 pm
Can you share a video of the play?
Posted : 08/08/2024 2:25 pm
its side to side at the wheel seems like its somewhere in the axle assembly when the rear thru axle is done up
Posted : 08/08/2024 6:48 pm
Weird . I once missed out the 1mm spacer that sits behind the freehub.
Does it spin alright i.e. the bearings are not mashed?
Not that I'd ever have cocked one up putting it in..... Well, not often.
Posted : 08/08/2024 6:51 pm
As per hillsplease:
My money is on the 1mm spacer that sits behind the freehub.
Assuming that you replaced the bearings in the freehub too. There are 3 in there.
Posted : 08/08/2024 7:05 pm
