Hope Pro4 FH Boost ...
[Closed] Hope Pro4 FH Boost conversion
Evening all.
Quick question ......
I have a Pro 4 front hub in std QR fashion.
Looking at a Boost fork.
I see you can get a Hope converter that looks to just sit on the NDS replacing a regular 15mm spacer.
My question is how much tweaking is needed to get the wheel centred again?
Is it in the "normal" tolerance of what is usual re nipple tweaking ๐Ÿ˜† ๐Ÿ˜ณ
Posted : 10/12/2017 6:33 pm
Yep.
As long as your wheel hasn't been built with spokes that're to short it'll be fine.
I've used the same converter on two different front wheels and it's a ten minute job to true the rim across.
Also trued a rear wheel across for a 6mm offset frame.
Posted : 10/12/2017 6:37 pm
Cheers Stu - now to buy a fork .....
Posted : 10/12/2017 7:44 pm
There is an adapter that needs no truing, it's two end caps and a spacer for the rotor. Not made by Hope but will fit Hope.... just can't remember it right now...
Edit: it's from [url= https://www.mrpbike.com/better-boost-adapter-kits/ ]MRP[/url]
Posted : 11/12/2017 12:03 am
