hi all i'm having play in my rear pro4 have replaced all bearing and still it persists has anyone encountered a cure such as thin shims or replacement parts ?????
cheers mark
Posted : 08/08/2024 11:31 am
Was there play before you changed the bearings?
Have you tried the wheel in a different bike?
Posted : 08/08/2024 11:33 am
You won’t need shims or whatnot. Something you’ve done or something worn out will be causing the problem. If you’ve replaced all the bearings, did you use good quality ones that are in tolerance? Is the axle worn?
failing that, get it apart again and look at the tech docs in Hopes website to see what’s wrong, worst case, ring them up, they have a service dept and don’t bite.
Posted : 08/08/2024 11:50 am
