Hope Pro 2 QR to 20...
[Closed] Hope Pro 2 QR to 20mm conversion
I have just received a hope pro 2 qr to 20mm conversion kit.
It has two spacers and one snap ring. I had a look at the Hope diagram and I can't see where the snap ring would go.
Will it be obvious when I remove the QR adaptors?
Posted : 14/03/2009 9:50 am
Snap rings like no. 4? There should be two I think, although thats a Bulb its the same idea
Posted : 14/03/2009 9:56 am
Yep, should be 2 snap rings, one to keep each spacer in.
Posted : 14/03/2009 10:01 am
Theres a vid on hope site too, I'l see if i can find it you use a biro to get the snap rings in
[url= http://www.hopegb.com/page_mep_force_4.html ]here it is[/url]
Posted : 14/03/2009 10:02 am
The snap rings hold the 20mm spacer in place. Theres a video on the hope website that shows how to convert from qr to 20mm. The qr adapters just pull out, push in the 20mm spacers fit the snap ring and your done. I did it last weekend on mine.
Posted : 14/03/2009 10:03 am
you should have two
Posted : 14/03/2009 10:04 am
you are indeed supposed to have two but on my bulb at least, (which dismantles exactly the same as that diagram up there) they just stop the spacer falling off the hub (not particularly structural) when you take it out of the fork. So I wouldn't let it stop you riding it, and hope have excellent customer support/aftersales so I am sure they will fire you over another ring by express carrier pigeon.
Posted : 14/03/2009 10:35 am
LOL!
Very true
Posted : 14/03/2009 10:45 am
I'll email the shop I ordered it from to get them to send me the circlip
Posted : 14/03/2009 1:10 pm
