Is this what I need to convert my Hope Pro 2 rear hub from 9mm QR to Maxle? Just not sure about the "Evo" bit whatever that means?
[url= http://www.ukbikestore.co.uk/product/176/hopepro2evokitr/hope-pro-2-evo-conversion-kit-rear.html ]Hope Pro 2 Evo Conversion Kit Rear, 12mm Thru (Maxle)[/url]
Also can someone post a link to some instructions and do I [i]need[/i] to replace the bearings at the same time (they're fine at the moment).
Thanks.
If you have the original Pro II's then its not what you need, you need one of these,
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21849 ]12mm axle kit[/url]
if you have an evo ProII then you need the adapters you have found 🙂
Ah ok, It's not an Evo as far as I'm aware. Shame, I thought I'd found it for 5 quid cheaper there 😕
