Hope pro 2 - I'...
[Closed] Hope pro 2 - I'm a numpty probably
So, I put a new freehub body on a hope pro 2, new pawls and bearings etc. All fits and spins fine, nice click when you spin the cassette.
But as soon as I put it in the bike it's like a fixie.
Took it all off, done it all again ... same again.
What have I done wrong??
Posted : 07/05/2014 8:19 pm
You've missed the little spacer out from behind the freehub body. It's a washer about 2mm thick that slips over the axle first.
Stops the freehub from binding against the ring drive once you load the wheel up with the skewer
Posted : 07/05/2014 8:20 pm
 lerk
Or failing that, you may have inadvertently knocked the axle through the hub towards the NDS... If the spacer is there give the axle a clout with a block of wood on the disc side..,
Posted : 07/05/2014 8:27 pm
Or you either haven't installed the plastic freehub seal correctly or it's the wrong way round.
I knew it would be something daft. The previous one had collapsed so I had nothing to "copy" from.
Cheers Amigos !
Off to the workshop...
Posted : 07/05/2014 8:43 pm
