I've got a Pro 2 wheelset that I was converting to 12mm thorugh axle. I do the change and I can't get the maxle through the hole to mount the wheel on the bike.
Peering up the tube, there is a restriction in the middle. Why would a 12mm thru axle have a qr sized hole in the middle. What an I missing?
Have you changes the aluminium hope axel or just the end caps ?
wot Liftman said.
Sounds like a std axle tube! The std. Pro 2 QR axle tube has a 12mm hole about a third of the length of the tube on the freehub side, and a 10mm hole about the same length/depth on the other end, the centre is as you say a restriction with a hole just big enough for a std. QR to slip through. What end caps are on it ?
Did you buy pro 2 EVO adapters for a pro 2 hub?
Looks like I've been diddled, then. 12mm adaptors on a std axle.
I could have saved myself half an hour and just changed the end caps to get where I am.
Sigh
It is possible to run a 12 mm drill through the axle if you are careful
Hmm, that would get me rolling tonight, but must be a weak spot.
ScottChegg - MemberHmm, that would get me rolling tonight, but must be a weak spot.
Well. Yes it will be but that's exactly how Hope do it, the external dimensions are the same (I think maybe all the axles are cut from the same blanks). So if you do it well it'll be exactly as weak as an official Hope one.
My 12mm axle tube has more metal in the area between the 2 main hub bearings than a std QR tube. Yes they can be drilled out, but will be a fair bit weaker. You may get away with it if you use a solid 12mm through axle ๐
