Hope pressfit bb / ...
[Closed] Hope pressfit bb / sram force. Wavy washer
 DT78
Have a new bb coming. Can’t seem to find the answer online. I presume I do not need to fit the wavy washer to a sram force crank when using a hope pressfit bb?
Posted : 14/04/2019 9:19 pm
If it's a GXP crank you will still need the washer.
Posted : 15/04/2019 6:05 am
 DT78
yes GXP crank - I thought the washer was to hold the seal in place on the gxp bb, hence why I was thinking it might not be needed on a hope bb with the gxp conversion.
I suppose worse case, it'll be too tight and bind and I'll have to take it back off
Posted : 15/04/2019 9:29 am
My Hope/GXP combo was binding a bit so I removed the wavy washer. Doesn't appear to have made any difference and BB has survived a winter of CX racing.
Still binds a bit though, just enough that the cranks won't spin freely for very long when you give them a spin. Don't notice when I'm riding.
Posted : 15/04/2019 10:56 am
 DT78
surely the binding is costing you a good few watts?
Posted : 15/04/2019 1:27 pm
I have used sram gxp cranks in a Hope bb with no wavy washer and it worked fine. I am sure it is only needed for non-captive seals like the ones with Enduro bearings.
Posted : 15/04/2019 4:45 pm
