Swapping out hydrau...
[Closed] Swapping out hydraulic calipers
[#10583099]
I’m looking to swap out some shimano hydraulic callipers. Will I need to cut the hose short and re-fit a new ferril and olive or can I re-use the one that’s already there?
Ta.
Posted : 14/04/2019 10:24 pm
Officially you should replace the olive. In reality, if you're careful you can reuse them
Posted : 14/04/2019 10:30 pm
Do you need to cut the hose? Just unbolt and bolt it onto the new caliper
Posted : 14/04/2019 10:41 pm
No, no need to shorten the hose, just replacing the calipers so ideally i’d Just unbolt and replace. I’ll give it a go. Thanks.
Posted : 14/04/2019 11:09 pm
