Hope Pick n Mix Siz...
[Closed] Hope Pick n Mix Sizes...
Apologies in advance for my lack of knowledge, but can anyone advise which Hope Pick n Mix headset cups I will require for a v2 Scandal with top 1 1/8 and bottom 1 1/5?
What's diff between Integral and Integrated?
Top - 1 1/8" Integral (43.95 dia)
Top - 1 1/8" Integrated (41.1 dia)
Bottom - 1.5" Integral (55.9 dia)
Bottom - 1.5" Traditional (49.57 dia)
Muchos...
Posted : 23/08/2013 12:59 pm
Integral has cups you press in - they just sit inside the frame
Integrated - I don't think you press in cups - it's just a bearing that runs in the frame.
Traditional - cups to press in and they sit above and below the frame.
When I needed a new headset for a build - I just went with the diameters (44 and 56mm) in the frame's spec and it narrowed down the choice.
Edit - just to clarify, this was the size for my frame, not sure about yours, sorry!
Posted : 23/08/2013 1:19 pm
http://www.on-one.co.uk/i/q/HSOOSMTAPER/on_one_smoothie_mixer_tapered_headset
On the spec sheet - if yours is a 29'er v2 it says the above headset is recommended.
Posted : 23/08/2013 1:24 pm
So......if I want the Hope variant, I need integral?
Posted : 23/08/2013 9:17 pm
