Hope mtb hubs for r...
[Closed] Hope mtb hubs for road/gravel wheel-set?
Can I build a pair of disk equipped road wheels using a hope XC and Hope bulb hub from a set of mtb wheels i have in the shed?
Fairly embarrassing but as far as road stuff goes i haven't got a bloody clue.
If so can anyone recommend rims at the lower end of the pricing spectrum that are considered non anchor like in weight?
Cheers in advance
Posted : 18/02/2016 7:55 pm
I use Hope xc hubs laced to Pacenti CL25's on my road bike with either 25 or30mm tyres. Fine. Going to swap the rear to a newer Hope to allow 11 speeds.
Posted : 18/02/2016 8:00 pm
Magic open sport £30 475gm
Posted : 18/02/2016 8:03 pm
 gee
If it's an old hope rear hub it won't work with 11 speed road. So you'll need a Pro2 11 speed freewheel. Only fits Pro2 I think, so if you don't have one of those and want to run 11 speed you can't.
Posted : 18/02/2016 8:18 pm
No worries, planning on sticking with the 10 speed Tiagra on my current frame when i shift over.
Posted : 18/02/2016 8:32 pm
Is it a 135mm spaced frame? Road bikes are normally 130mm. Though it's not necessarily a dealbreaker...
Posted : 18/02/2016 9:00 pm
 mlke
Stan Iron Cross tubeless rims on my tourer. If it's pure road then I'd suggest getting some cheap Shimano Ultegra wheels for speed
Posted : 18/02/2016 9:09 pm
Most disc cross frames are 135mm now. If yours isn't stretching the frame or shaving 2.5mm off each end cap isn't a big deal.
Hope Xc front and bulb Ti on the rear for me:-)
Posted : 18/02/2016 9:16 pm
Yep, you should be fine. Plenty of cheap rims available ( http://www.chainreactioncycles.com/rims/mtb-rims?f=4294957821&sort=pricelow).
I'd recommend the TN719 - should be reasonably light, durable and perfect for 28mm-ish tyres.
Posted : 18/02/2016 9:47 pm
Cheers Mike
Suppose it would be rude to not send the build buiness your way if you are able to fit it in?
Posted : 18/02/2016 10:23 pm
Hi Scandal,
Depending on hole count I've a set of new Pacenti rims that would work great.
Jon
Posted : 19/02/2016 9:17 pm
