Does anyone know for sure which adaptor is needed to fit IS mono mini to post mount fork? I have researched but confirmation would be good as not 100%.
http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
Looks like the one; but give Hope a call to be sure.
I used this one to fit a IS Shimano XTR calliper to a post mount fork.
Assuming mono mini is the same standard as XTR it should work but needs a +20mm disk
edit: oops too late!
I used one of [url= http://clee-cycles.co.uk/esite/P1043/product;jsessionid=A986DB1A6F4EAD54E892043AF758B82D ]these [/url] to attach a 180mm Hope IS mini to a post mount RS Reba with no need for an increase in rotor.
Pic of the adaptor below - (give me a shout if you need more pics)
