hope hub problems
[Closed] hope hub problems
1.The freehub on my xc hub is loose - won't fall off but there's play in it.
Took it all off and nothing obvious - tried a new end cap too.
2. Replaced outer bearings in pro2 rear hub and it freewheels ok but I can't backpedal - chain just wraps up.
Ideas on either anyone?
Ta
Will
Posted : 31/10/2012 10:16 pm
1.Worn spacer.
2.Missing spacer.
Posted : 31/10/2012 10:18 pm
 Bolt
3. Snapped axle
Posted : 31/10/2012 10:21 pm
Echo above re : spacer , Did you fit a new freewheel seal?, and is it seated correctly?.
Check the hope website for exploded diagrams to make sure you've not missed anything.
Posted : 31/10/2012 10:24 pm
1. Worn freehub bearing with play in it would be my guess.
2. Missing or mixed up spacer.
Posted : 31/10/2012 10:26 pm
He replaced the bearings in the freehub as well as the Hub bearings surely?.
Posted : 31/10/2012 10:28 pm
1 free hub bearings?
2 spacer as previously mentioned or seal between free hub / hub.
2.1 hub bearing in squint or axle not fully home.
Posted : 31/10/2012 10:31 pm
somafunk - Member
No mention of bearing replacement on the XC hub.
Posted : 31/10/2012 10:37 pm
Freewheel bearings?
Had the back pedalling issue with seized jockey wheel bearings ๐Ÿ’ก
Posted : 31/10/2012 10:38 pm
1. Worn bearings.
2. Too much grease around springsl/pawls or the seal isn't seated properly.
Posted : 31/10/2012 10:41 pm
Cheers folks will pull apart tomorow.
Xc hub has had no work so something just worn then
ProII - will check seal and spacer. Only did hub bearings as they were rough as. Freehub bearings were good - no play, ran smooth
Posted : 31/10/2012 10:51 pm
Reseated the seal and all is well with ProII.
XC hub another day
Ta
Posted : 31/10/2012 11:21 pm
