Hope Hose shorten.....
[Closed] Hope Hose shorten... do i need to bleed?
Just watched the Hope tutorial on Youtube wrt the hose shortening proceedure.
Do i need to bleed the brake after doing this? I would assume yes, just after confirmation from some guru of fetteling.
Posted : 22/05/2010 4:08 pm
hardly ever need a full bleed. just cut the hose and as you reconnect the hose squeeze the lever until a bead of oil comes to the head of the hose, get it back on the caliper, nip it up. then top up the resevoir with oil.
Posted : 22/05/2010 4:29 pm
Cheers for that, off i go again! ๐Ÿ™‚
Posted : 22/05/2010 4:32 pm
