Hope Hed doctor
[Closed] Hope Hed doctor
Is there a nack to getting them in? Can't get the o-ring into the steerer ๐Ÿ™
Posted : 25/05/2011 7:24 am
Unscrew the inner bolt until the collar is loose and can be easily compressed. Might need a bit of persuasion with a rubber mallet to insert it in the steerer. A chopstick up the steerer can be useful to press against the lower nut if it won't tighten.
Technically you don't really need the o-ring it's only there to hold the bits together.
Technically you don't even need a headset adjuster but that's another story.
Posted : 25/05/2011 7:33 am
Had this problem last weekend. I put a light smear of grease around it, loosened the bolt right off, pushed it in as far as the O ring, then just eased the O ring with a small screwdriver in as I pushed it down. I found the trick was not to push it in too far too quickly which completely traps the O ring at one point
Posted : 25/05/2011 7:38 am
Greased the o-ring and used a screwdriver to feed it in and job was a good 'un until I realised I had it upside down! Doh! ๐Ÿ˜ณ
Posted : 25/05/2011 8:16 am
๐Ÿ˜†
(when it's in, be sure to overtighten and then post up here that the bolts are made of cheese)
Posted : 25/05/2011 9:03 am
File a leading edge on the inside of the steerer tube.
Posted : 25/05/2011 9:26 am
I cut a lead-in chamfer (with a knife) on to the inside of the steerer tube - helped big time. It will give smoother results than a file.
Grease up the lead-in and the o-ring then loosen and compress the conic edge assembly gubbins.
FWIW the hed Doctor was more faff to put in than I rememberd (had one many moons ago); might not bother next time.
It does sound like you have it sorted now, but I have found that google loves to index singletrackworld threads.
For the future!
Posted : 25/05/2011 9:38 am
Ummm.. I *think* I removed the rubber O ring and it worked a treat.
Posted : 25/05/2011 9:44 am
Yep all sorted thanks
Did file down the steerer to give it a bit of a slope to drop into. Worked a charm and made it quite easy.
Posted : 25/05/2011 9:48 am
