Hope headsets- pick...
[Closed] Hope headsets- pick and mix
I have a 1 1/8 steerer fork and I have a tapered head tube - with a 44mm upper,56 mm lower (Transition) frame which requires an [b]internal[/b] headset. Can I choose from Hope's pick and mix range, if so which top & bottom cup do I need to choose?
Thanks
Richard
Posted : 11/10/2013 10:17 pm
Think 2E would do it. You can check their tech sheet here:
Posted : 11/10/2013 10:25 pm
You need the E and 2 cups with the extra 1 1/8->taper adaptor, assuming you want these for a 2013 covert frame.
Edit: beaten to it
Another edit, both cups in stock here for a good price http://www.ukbikestore.co.uk/product/productlist.aspx?red=1
Posted : 11/10/2013 10:28 pm
Thanks both.
Richard
Posted : 12/10/2013 6:07 am
